Welders
Scott
04-09-2000 08:22:24
I was interested in purchasing a welder that can weld sheet metal and also thicker types of steel and maybe cast iron.
Jhbue
05-29-2000 19:12:20
 Re: welders in reply to Scott, 04-09-2000 08:22:24
Scott
There are many different welders available.All depending on what you are going to be welding and how much.For thin metal(sheet metal 1\32nd to 1\8 I would go with a mig wire feed.If larger than that I would go with a stick welder and if you are doing both try a milleromatic tig or equale.It will weld steeland braize.Comes with a argon tank and foot petal for aluminine.It is ac and dc so if you put it on dc and have some nickle rods cast iron and a little practice your in buisness.
Paul Fox
04-09-2000 14:32:45
Scott, do an archive search on welders or welding. This subject was discussed in some depth a month or so ago, with a lot of great advice.
