Best valve spring clamp for Cub flathead engine
Don Hannis
09-26-2002 07:53:09
As this is my first re-build I plan to acquire all of the needed tools. Before I take a chance on the wrong clamp I thought I'd ask the experts which one is best.
Thanks
Don
SEAMO
09-26-2002 18:52:12
 Re: best valve spring clamp for Cub flathead engine in reply to Don Hannis, 09-26-2002 07:53:09
Your local Auto parts store should have what you need. I have used both styles the "C" clamp style you can use on L head engines or OHV. They make another that is scissor type that will just work on L head. Some times you can rent them at the tool rental. Are you going to grind the valves yourself. If not the machine shop can R&R them. Earl
