Grinding tires
R Keenan
09-21-2002 19:39:37
Does anyone know what kind of a tool you can use to grind tires for tractor pulling? I've tried grinding wheels and sander discs without success. Thanks!
Paul
09-22-2002 19:53:42
 Re: Grinding tires in reply to R Keenan, 09-21-2002 19:39:37
a powerplane works good
MAD DUC
09-22-2002 17:26:08
Try posting this in the Pulling section here, then hopefully we will get some more options since I'm interrested in this also.
Gary
09-22-2002 15:58:53
Try a local commercial tire company or a retread place they may tractionize big tires "they call it siping tires" nowadays. Good luck.
the tractor vet
09-22-2002 10:44:29
They make a special disc that goes on a 7-9 inche grinder that is made of steel with like a laser weld metal grit on it , you can get them from a tire tool supply house . That is one nasty job and it will also scrap out a grinder in no time . If you are going to do this then get a real heavy duty 9 inch grinder and keep it blowed out and be extra careful that just the tire get ground and not youbecause that wheel will EAT YOU .
