Diesel oil in a car engine?
John
09-20-2002 04:33:45
After reading about someone running diesel oil in a 350 chev, I had to ask. Is 15-40 for trucks a better choice for heavy duty pickup use? How about truck antifreeze?
Trucker
09-20-2002 23:27:06
 Re: Diesel oil in a car engine? in reply to John, 09-20-2002 04:33:45
I was a mechanic for a long time,I rebuilt diesel engines.I dont know about real new engines,its probobly better to use what they call for in them,but on old engines,you can use 15-40 diesel oil in any engine.The difference in diesel oil and gas oil is that diesel oil has more detergent in it.Now if you have an old,old engine that used straight weight oil,and for years and years was not rebuilt,the extra detergent could knock the crud loose in the engine and plug up something like an oil gallery.I know from experience that an engine that used series 3,or 30 weight diesel oil,would be a lot dirtier inside than one that used Shell 15-40.Now there are other brands,but I dont know about them.Shell was first,and I use it in my truck.I know kendall is good Diesel oil in 15-40,the others I dont know,but they have to pass tests and it should say on the label what tests they passed.Ive had the best luck rebuilding an old motor like for a pickup,and useing Shell 15-40 in it.Real old motors like caterpillars,that called for 30 weight,series 3,or whatever you call it,would leak out of the mains if you switched to multigrade oil.They designed new seals that fixed the problem,and if you get a piece of equipment that has been used since the late 80s,and has been rebuilt,chances are that it has the new seals in it.Now when people used series 3,we changed rod and main bearings in cummins motors about every 100 thousand miles.Now that everybody uses 15-40 Shell or something thats passed the same tests,its not unusual for a diesel engine to run 7 or 800,000 miles and not be touched by a wrench.I like to look at the bearings after about 300,000 miles,but I change them when I look at them,and usually I think I wasted my time,they would have gone a lot further.I would say that unless somebody has another reason besides breaking loose sludge,or a new engines tolerances,diesel multigrade would be good,and most likely better than gas oil in any engine.I also noticed that if you have an engine that leaks a little bit with 10-30,might quit leaking with 15-40.Also if a motor is so dirty inside that the diesel oil breaks the crud loose,it probobly needed to be rebuilt anyway.It might run for years if you didnt put the diesel oil in it,but it might not run but a few minutes and the stuff fall out of somewhere and clog a gallery.I know the oil is better,and diesels run day and night up mountains and in all conditions,and with longer service periods.You just have to use your own judgement on a motor,and if its allways had the oil changed,didnt idle much,and clean inside,I think it will work.Also it needs to be from the time multigrade oil was specified for the motor,as I know old cat seals will leak,other brands werent so bad about that,but they might leak some as 15-40 is lighter than 30 weight a little when its cold outside.Most likely even on an old motor if you put new seals in,they are made for multigrade oil,but you need to ask,and cosidering how much better multigrade oil is,insist on seals that work with this oil,as the old oil is outdated and may not even find it.
thurlow
09-20-2002 17:43:37
John; I would be at least as concerned about the API ratings for oil as for the viscosity. These are the letters inside a circle somewhere on every container. Letters beginning with S are for gasoline engines; letters beginning with C are for diesel. If the oil in question doesn't have the right letters, I would definitely not use it in the engine in question. As for viscosity, I would depend on the engine maker's recommendations, depending on expected temperature and operating conditions.
Kendall
09-20-2002 07:40:57
If you look on a jar of 15-40 you will see its rated for both diesel and gas engines and often called "multi grade". Nothing wrong with running it in your car, unless like Don says, your newer cars call for 5-30 because the precision tolerance in new engines are so much closer nowdays. Thats why engines are lasting longer now. However if you have a car with billions of miles on it, this oil might be just the ticket you're looking for.
Don LC
09-20-2002 05:37:16
Diesel oil in any engine is OK....Before I retired I worked in Researcd & Development for a large Co.....part of my job was to search for new packing materials for our products.....That gave me the chance to talk with other companys about there products....One was Shell oil co.,they make a diesel oil called Rotella-T.....it comes in 15w-40, as well as standard wts.They said that was the best oil they made...They call it there fleet oil, use it it gas and diesel trucks..or any engine... I have used this oil in my engines for over 25 years....I don't use it in my new ford van ,because ford wants 5w-30 in it....I tried 15w-40 and the gas milage dropped off about 2 miles per gallon ....went back to 5w-30 in the van only....I can't talk to Shells research guys any more,as I am retired..... .I will tell you, I rebuilt a '72 ford v8 with 97,000 mi. the valley was a clean as a pin....
Tom
09-20-2002 17:49:03
 Re: Re: Diesel oil in a car engine? in reply to Don LC, 09-20-2002 05:37:16
But why did you need to ribuild it with only 97000 on it? I consider an engine at mid life or less at that point.
Keith G.
09-20-2002 10:32:39
I use Amsoil 0-30 in the wifes van, 348K and never even replaced a gasket so for.
Ludwig
09-22-2002 19:30:27
 Re: Re: Re: Diesel oil in a car engine? in reply to Keith G., 09-20-2002 10:32:39
Thats the kind of stuff I want to hear.
I've been reading alot about amsoil. I'm danged tempted. I ordered some of the 2 stroke oil but it has yet to arrive. I'm going to order some of the other and give it a shot in a small engine first. If that works out okay I'll try in the truck. I was actually thinking about getting a cheapo car just to test it in. Supposedly great stuff.
Keith G.
09-20-2002 10:29:24
if the rotella is so good why the rebuild at 97K?
Don LC
09-20-2002 12:23:34
 Re: Re: Re: Diesel oil in a car engine? in reply to Keith G., 09-20-2002 10:29:24
Expensive,rare 427 cu. side oiler,with two fours=456HP..... needed to be freshened up....I drove it on the street and raced it every weekend..... .didn't want to lose it....this engine cranked 7,000 RPM that is pretty good for an old ford.....
Glenn(WV)
09-20-2002 19:01:42
 Re: Re: Re: Re: Diesel oil in a car engine? in reply to Don LC, 09-20-2002 12:23:34
YOW! I looooo ove those engines!!! PLEASE tell me you still have it!!
rogerf
09-27-2002 11:39:34
 Re: Re: Re: Re: Re: Diesel oil in a car engine? in reply to Glenn(WV), 09-20-2002 19:01:42
Or better yet please tell me where it's parked at nite and when no one will be home.....I really hate rock salt
Ray,IN
09-20-2002 09:15:32
I agree. The 5Wxx and 0W30 oils were blended so auto mfgrs could meet the CAFE requirements; thus the 2mpg difference from 15w40.
