Shakin
JD G GUY
09-15-2002 18:01:33
ive got an 89 chevy light duty 2500 and i just did the cap/rotor/wires and now its shaking are some of the wires arching because some of the wire looms are broken ( ill be getting new mr gasket chrome ones) :-) or is something else wrong. please tell me something else is wrong because i just had the trany go out and im about ready to sell it. thanks ahead of time, and sorry for grammer and spelling mistakes along the way.
TURTLE
09-16-2002 13:03:18
 Re: shakin in reply to JD G GUY, 09-15-2002 18:01:33
IF IT STARTED AFTER YOU REPLACED YOUR WIRES AND SUCH YOU EITHER CROSSED YOUR WIRES OR GOT ONE OFF ON YOUR CAP. CHECK YOUR FIRING ORDER. IT WILL BE CAST INTO YOUR INTAKE. IT IS POSSIBLE YOU GOT A BAD WIRE OR PLUG BUT IF IT SHAKES RADICALLY IT'S PROBABLLY THE FIRST.
Ludwig
09-16-2002 12:45:23
I'd bet on crossed wires before anything else.
You didn't use split fire plugs did you? I had those in my Dakota one winter and it got so you couldn't hardly drive it. Replaced them with cheapo AC plugs and its fine ever since.
Sam#3
09-16-2002 06:18:47
I agree with the possibility of frogged wires. You're in a better position to determine arcing, just wait until dark start it and look.
ferrell freeman
09-16-2002 00:42:40
Like Glenn, said I,have seen wires and plugs bad from the parts store . Did you, check the gape on the plugs ? I,know most of them say they are pregaped ,but in shipping and handleing they could of been dropped .If you, have a vaccum gage use it to see if there is valve trouble and or a vaccum leak .
Mac
09-15-2002 19:41:04
Did you use carbon wires or cable wires. I have seen some vehicles that would not run right on cable type. Plug wires back on right plug? Have seen bad dist. right out of box. Wires should not arc. As informed, maybe a bad plug wire/wires.
Don LC
09-15-2002 19:49:03
 Re: Re: shakin in reply to Mac, 09-15-2002 19:41:04
Sounds like a crossed wire..... .
Glenn(WV)
09-15-2002 19:19:30
I'm wondering if you have either a bad wire or a bad plug. Have you tried pulling off the plug wires to see if the shaking is worse with each one? If you pull one off and the engine runs the same, you've found either a bad wire or a bad plug. I've seen both new plugs and new wires that were bad from the auto parts store, so it's a possibility.
JD G GUY
09-16-2002 17:11:31
 Re: Re: shakin in reply to Glenn(WV), 09-15-2002 19:19:30
went out to the garage this afternoon started checking the plug wires to make sure they were on the right cylinder turns out 5 and 7 were mixed up thanks for the help
gotta remember 1-8-4-3-6-5-7-2
