Welder Help
Jeff
09-14-2002 17:42:16
I'm sure its been asked and reviewed on here before, but, I couldn't find anyting so here goes.
Has anybody ever used a Lincoln AC/DC buzz box to do any TIG welding?
I have a few small exhaust systems for competition karts to build and I need a power source. I have my TIG torch, hose and regulator.
Thanks in advance,
Jeff
Tommy Boy in PA
09-15-2002 18:18:49
 Re: Welder Help in reply to Jeff, 09-14-2002 17:42:16
Check this out.. I think this is what you are looking for>Link
Hope>Link this helps,
Tommy Boy
T_Bone
09-15-2002 09:57:55
Hi Jeff,
You sure can use a buzzer for Tig. Use straight polarity, DCSP, DCEN. Thats how I learned Tig, was with a scratch start Tig torch. The fancy reostat amp control was for the high end shops and not very many of them to boot.
You'll need to clean the scale off the steel as well as the filler rod to keep prosity out of the weld puddle.
T_Bone
Mike W
09-14-2002 20:30:55
Hi Jeff: I have a Linde ac buzz box. I bought a used Lincoln high frequency box for it. I then built a scr voltage control on the 220 input. It uses a home made foot control. I also added a 200 amp rectifier for dc. You can do a scratch start using dc. For aluminum, you need ac and constant hf.
