Fordson Dexta wheelbase adjustment
mark spagnolo
09-13-2002 08:45:59
I have a dexta which I intend to use on some significant slopes and I understand how to spread the front wheelbase. I'm not so sure if it is as straightforward a process to spread the back axle/wheels. Any advice out there? I'd appreciate any feedback, cheers Mark Victoria/Australia
Burrhead
09-13-2002 18:28:33
 Re: Fordson Dexta wheelbase adjustment in reply to mark spagnolo, 09-13-2002 08:45:59
If it's the original style wheels here goes.
Take the tires off at the outter ring bolts, not at the center wheel bolts.
The easy way to do it is to jack up both sides and rotate the tires. That way the tread still travels right and it keeps the wear more even. If you're brushhogging you run it wide. If your running a planter or 2 row cultivator you run it narrow.
