tungsten carbide mixture
tom mostorf
09-12-2002 21:20:22
Has anyone heard of tungsten carbide mixture for re-tipping bits. It is a tungsten carbide chips,brass beads and flux. If you have where can I get it.
Steve U.S. Alloys
09-13-2002 05:36:52
 Re: tungsten carbide mixture in reply to tom mostorf, 09-12-2002 21:20:22
My company will have that material in stock. The mesh size of the carbide varies. If you have a particular size in mind you will want to relay that. We also have a tinning rod if required. The tinning rod flows very thin and can aid in wetting the carbide bearing alloy. It's usefull but not absolutely necessary if the bit has some of the old coating still intact. Each rod will weigh one pound. 1-800-325-1568 Steve
