Phase converters
Mark Lynch
09-12-2002 13:05:37
Does anybody know how to run a 3phase motor off of single phase? 220v single to 220/240v 3 phase.
Any info would be appericiated.
Bus Driver
09-14-2002 10:58:17
 Re: phase converters in reply to Mark Lynch, 09-12-2002 13:05:37
My opinion is that the absolute best way to convert single phase to three phase is with a VFD- Variable Frequency Drive. Some manufacturers call them inverters. Small, quiet, extremely efficient and versatile. Gives a better three phase for motors than the other types of convertors. If using with single phase input, get a VFD with about 1 1/2 times the HP output of the motor you are using- a 3HP motor would use a 5HP VFD. Look for VFD on eBay- many of those sellers also have Websites and sell directly. Mine will furnish 3 phase output at any frequency I desire from .1Hz to 400Hz in increments of .1Hz. My milling machine motor works well from 40Hz to about100Hz so that gives me lots of speed ranges.
T_Bone
09-13-2002 22:00:29
Hi Mark,
You might want to read up on poly phase (A true 2-phase 230v circuit) and how "run" capictors effect voltage waves or phase angles. You will find some very interesting reading that will lead you too what your looking for, cheap.
A true single phase is a 115vac circuit!
Just be very careful when you start to think you understand what you read and apply that to high voltage as high voltage is very unforgiving and it can kill you deader than a door nail. :)
T_Bone
Chris mf35
09-13-2002 18:55:37
the's the link i've posted before for building a rotory convertor.
Link
Jim WI
09-13-2002 10:03:01
Also consider using a variable-frequency AC drive. They've come down in price dramatically over the years.
What's the current rating on the motor?
TimC
09-13-2002 06:34:18
You could buy a phase-o-matic for a couple hundred bucks to start a 3 phase motor with 220 single phase.
It is cheaper to use a 220 motor and short belt to start a spart 3 phase motor, release the tension on the 220 motor and let the belt fall off in the floor. The spare wires coming from the three phase motor that is also setting in the floor, running by being started manually, will produce the third phase you need to run your equipment.
Sound crazy but, i know of one machine shop a buddy runs from his home that has a crank grinder, power hone, 2 boring machines, hot tank, and numerous other machines running and he has never had a problem. He spent the money on the Phase-o-Matic so he doesn't have to deal with the belts and 220 motor to start his 3phase motor that creats the third phase.
Sorry about putting this in first graders terms by i couldn't draw it out and make a picture.
G Taylor
09-13-2002 06:15:36
If getting a three phase service installed or converting/re-winding the motor to single phase the results will better/less fuss. A solidstate three phase variable frequency drive will allow variable speeds,soft start and reversing. A rotary convertor does work, can have spin up problems and requires capacitors to reduce phase shifts and over heating on one phase leg.
DaveInMI
09-13-2002 04:39:14
Lindsay Publications has a little book explaining how to make your own, both static and rotary types.
Bob
09-12-2002 20:32:56
ENCO is one source.
Link
They're on page 190 of their on-line catalog.
You need Acrobat reader to access the catalog.
Search for Item #297-3510. That should take you to the proper page where there are other models listed also.
LeeJon
09-12-2002 19:11:37
I have used one for 20 yrs.,static and rotory type Favor the rotory.When you purchase one, the hook up instructions come with it. I'm not a certified electrician but have a fair knowledge about it. I hooked both up with no problems. One thing to remember is don't use the third phase for the on off switch. This was a caution on the hook up instructions. If you have no instruction you had better contact
a knowledgable electrician.
Light Bulb
09-12-2002 18:19:43
Take a look around your area and see if there are any 'coyote' welder repair people. Word has it they are good with electrical repairs and modifications to motors, welders, electrical controls, etc.
VaTom
09-12-2002 17:12:18
A search of this site for "phase converter" will give you the links you're looking for. I've been running one or another for the last 20 years. Make sure it's a rotary, not static, if you have a newer tool.
JMAC
09-12-2002 15:53:13
MARK, GET ON THE INTERNET,I USE GOOGLE AS A SEARCH ENGINE, TYPE IN PHASE CONVERTERS, YOU WILL GET ALOT OF BUSINESSES COME UP BUT IN THERE WILL BE A FEW ACTUAL SITES(INDIVIDUALS) WHO HAVE POSTED ON THE NET THE ACTUAL PLANS FOR MAKING ONE. JUST DOWNLOADED A COUPLE MYSELF THE OTHER DAY.
GOOD LUCK!
