Tool for Farmall C governor bushing installation
Patrick Brown
09-09-2002 06:27:52
I need to know if there is a tool that I can install a governor bushing into the engine block of a Famall C tractor?
Bill Hires
09-09-2002 10:29:46
 Re: Tool for Farmall C governor bushing installation in reply to Patrick Brown, 09-09-2002 06:27:52
I use an old governor gear and shaft that has everything removed, weights and sleeve, etc. Place the bushing in your deep freezer over night, or use dry ice if you have that available, put oil, or grease in the bore, place the frozen bushing on the shaft, be sure it is properly aligned, use a plastic hammer and tap on the gear to drive the bushing in. You might get this to work with your governor. I have a governor gear/shaft if you would like to use it, give me your mailing address.
Salvage Man
09-09-2002 07:02:25
I use a cam bearing driver to install them.
Patrick
09-09-2002 07:50:48
 Re: Re: Tool for Farmall C governor bushing installation in reply to Salvage Man, 09-09-2002 07:02:25
Where can I get a cam bearing driver?
Salvage Man
09-09-2002 22:25:42
 Re: Re: Re: Tool for Farmall C governor bushing installation in reply to Patrick, 09-09-2002 07:50:48
I got mine from our local Napa parts store
