Buffalo Forge
Dennis Benson
09-07-2002 10:46:30
Hello,
I just bought most of a forge with the name Buffalo Forge Co. on the blower. It looks like there are some pieces missing from the blower. I thing there is at least a gear cover and crank missing. The shaft that turns the gears looks like it supposed to have a crank, and turn the gears. There is no connection between the gears and the shaft with the fan. Does anyone know what is missing?
Thanks, Dennis Benson
F14
09-08-2002 08:59:00
 Re: Buffalo Forge in reply to Dennis Benson, 09-07-2002 10:46:30
You're right, it was most likely hand-cranked.
Mine is not a Buffalo, but I'd expect they'd all be similar. On mine, the shaft the fan is on also has a gear that meshes with the rest of the geartrain. Is there a bushed hole in the casting where another stub shaft and gear might go?
Dennis Benson
09-08-2002 09:26:08
 Re: Re: Buffalo Forge in reply to F14, 09-08-2002 08:59:00
There is a shaft going through the fan, but there is no gear on it, it had been taken apart recently, and I suspect they didn't replace the gear on the fan shaft. It looks like if I'm aptient I can make another gear and cut the teeth with a hack saw. They are helical teeth, and the gear is about 1 inch in diameter.
Dennis Benson
Roger
09-11-2002 21:01:41
 Re: Re: Re: Buffalo Forge in reply to Dennis Benson, 09-08-2002 09:26:08
Buffalo forge is still in business.I know for sure that they make huge industrial blowers and I believe they still may make tuyere and blowers for the blacksmith.I would suggest consulting with Cumberland General Store catalog.
