Hydraulic tire bead breaker,homeade or factory
Captain.n/e,Mo.
09-05-2002 20:00:45
many years ago I saw a tractor tire reparair dude in the field fixing one of our tires ,he had a hydraulic bead breaker.It had a small cylinder and two arms that reached around the tire ,one grabbed the rim and the other squeezed the tire down ,this thing was used on the tractor,don't remember how it was powered. Has anyone ever seen one of these if so where can I get one,or get plans to build one.I have a slide hammer type and it uses too much energy(my energy)to operate.
Mike
09-10-2002 07:57:50
 Re: hydraulic tire bead breaker,homeade or factory in reply to Captain.n/e,Mo., 09-05-2002 20:00:45
I have an extra hyd bead breaker to get rid of if anyone is interested.
F14
09-06-2002 03:05:13
Have you looked into rebuilding and/or remotoring the one you have? My Dad had a Craftsman back in the late 50's-early 60's. Rod's right, the new stuff isn't up to standard unless you plan to part with BIG bucks.
I bought my first tablesaw 4 or 5 years ago. Didn't look at Craftsman, as all their power tools I've ever had have been junk. Wound up with a 10" Delta Contractor. Good solid machined steel top, fully adjustable trunion that you can actually square up to the table and the fence, adjustable miter stops, good power. The base and table extensions are stamped, and I didn't upgrade to the really good fence, but other than that, I'm satisfied. Price hovers around $600, you can beat that if you shop.
F14....Ooops
09-06-2002 03:05:55
 Re: Re: hydraulic tire bead breaker,homeade or factory in reply to F14, 09-06-2002 03:05:13
Wrong thread...
Rod (NH)
09-05-2002 21:58:39
Check out the link. It's not hydraulic but it does break the bead...even on the tractor. I've been thinking about getting one myself one of these days.
Rod
Captain.n/e,Mo.
09-06-2002 04:24:05
 Re: Re: hydraulic tire bead breaker,homeade or factory in reply to Rod (NH), 09-05-2002 21:58:39
looks like it would work,simple too
cannonball
09-06-2002 20:16:16
 Re: Re: Re: hydraulic tire bead breaker,homeade or factory in reply to Captain.n/e,Mo., 09-06-2002 04:24:05
i have the bead buster works great....changed tractor other day left rim on it worked real good
