Car Muffler repairing
Steve Malknecht
09-04-2002 19:27:47
I was wondering if there are any type of repairing tape or something to repair a muffler crack? Thanks Steve
bob
09-05-2002 10:52:19
 Re: Car Muffler repairing in reply to Steve Malknecht, 09-04-2002 19:27:47
unless real sure you don,t want to buy new muffler you can use muffler cement napa did sell it have used it on mufflers and used it a lot at power plant to stop a coal leak untill could get equipment down to work on.
Don LC
09-05-2002 05:27:59
Steve --- Look in the phone book for "TOP VALUE MUFFLER" they put one on for me a while back for about $40....they will give you a price over the phone.....
Mike W
09-04-2002 20:56:54
I have heard of metal tape, etc. I think they are the triumph of hope over experience. If the muffler is fairly new, it might be welded. If old, it is probably shot.
Don Young
09-04-2002 21:59:00
 Re: Re: Car Muffler repairing in reply to Mike W, 09-04-2002 20:56:54
There are kits using fibreglass or wire screen and either epoxy or a furnace cement type compound. Either will hold for a while.
Chester
09-06-2002 17:00:41
 Re: Re: Re: Car Muffler repairing in reply to Don Young, 09-04-2002 21:59:00
If that is a crack in the pipe, cut an additional 3 or 4" section then split it lengthways then put it over the crack and pull it into position with two muffler clamps. If on the muffler, cut a sleeve out of 22ga. sheet metal ( or other ) so that it just wraps around the muffler. To hold in place, get some metal strapping and cut to just reach around the muffler, then fold back the last 3/4" on each end. Punch or drill holes there and install over the sheet metal sleeve. Pull it tight with a couple 1/4" bolts and washers. You can apply muffler cement ( stove cement ) to any places that need extra help in sealing leaks. When you do eventually replace the pipe/ muffler, save that stuff you made..... .....you'll use it again once you have it. Last month on the night before a 5000 mile trip, the pipe broke off behind my muffler..... ....did that pipe repair and it lasted the whole trip. Made up a new pipe when I got home.
