Bishman tire changer
8n?9n?
09-02-2002 07:38:23
I have a bishman tire changer model number 880-61 and I need the main drive gear the parts book lists it as the main drive gear and shaft part no 8018 if anyone can help with parts i would be thankful thanks in advance
Gary Mayhew
07-27-2005 18:22:18
 Re: bishman tire changer in reply to 8n?9n?, 09-02-2002 07:38:23
I have an antique Bishman Tire Changer Model #61 and I need parts for restoration.
Equipment Service Corp US
03-22-2006 09:57:07
 Re: bishman tire changer in reply to Gary Mayhew, 07-27-2005 18:22:18
We can supply many parts for Bishman equipment. Our number is 401-737-5885. Thanks
ted
06-24-2004 09:52:23
Hello,
I am trying to locate any information (parts list, manual, etc) on a Bishman tire changer model 888. (I can barely read the i.d. plate)
It is totally powered by air and has a cam type rim clamp with the three little wheels and a dual bead breaker (top and bottom beads).
I will continue to search as well and will share info.
Thanks for any info that you might offer.
Dean R. Hubbel
10-31-2003 07:10:37
Dear Dick Collingbourne, I too need info for a Bishman spin balancer, Model #81. Have you gotten any info for patrs etc. for your Bishman product? I am in need or forced to buy another spin balancer :-(
Dick Collingbourne
09-12-2003 14:16:30
If you find where Bishman parts are available please let me know. The machine I have is combined air and electric. The 3 little rollers that lock on the wheel when the handle is turned are worn and need replacing.
Chris Hanly
05-20-2004 12:05:01
 Re: Re: bishman tire changer in reply to Dick Collingbourne, 09-12-2003 14:16:30
Have you ever found any parts? I have an modle 888 that is missing some springs on the dismount sleeve on the lower side.
Dean
11-03-2003 19:09:33
I am looking for parts for a Bishman spin balancer. I think I found the parts you need on ebay, search for Bishman, there are tire changer parts, looks like the ones that wear out..
