Open for suggestions.....
Tommy Boy in PA
09-01-2002 20:24:26
After trying to find a replacement gas tank for my John Deere A, it looks like I may have to repair or replace the entire top half the gas tank...it is really bad...mostly rusted away. I am experienced with all types of welding and brazing but have little experience with repairing gas tanks. What would you do? I am really open for any and all suggestions.
Thanks,
Tommy Boy
Ludwig
09-02-2002 11:04:23
 Re: Open for suggestions..... in reply to Tommy Boy in PA, 09-01-2002 20:24:26
If the tank has SOME metal in it, like if the holes are 1" or smaller check out POR-15, www.por15.com and their tank sealing kits.
Hint, get the bigger kit, its worth it. I need to get another small can of sealer, my 4 gal snowmobile tank isn't quite done with one small can.
DON LC
09-02-2002 07:27:49
The first thing I would do is ask the guys on the JD page for help finding a used tank....I don't know what the tank looks like,but if you think you can replace the top half ,then coat the inside with the epoxy tank sealer.....I think J.C.Whitney sells a kit....( www.jcwhitney.com ) their order number is 1-800-529-4486 ....If the tank isn't just falling apart you may get the loose rust off by puting a 1/2 gallon of nuts and bolts in the tank and shaking it around to beat the rust off....then using the epoxy to recoat the entire inside of the tank.....
F.E.Bear
09-02-2002 14:35:14
 Re: Re: Open for suggestions..... in reply to DON LC, 09-02-2002 07:27:49
Instead of a half gallon of nuts and bolts, I use old cross chains from tire chains. They do the same job and are MUCH easier to get out out of the tank when you are finished. Just take a coat hanger and pull them out. My $.02
F.E.Bear
09-02-2002 14:34:46
F.E.Bear
09-02-2002 14:34:07
F.E.Bear
09-02-2002 14:33:54
wrenchman
09-02-2002 01:13:08
have you thought about copying your old tank??? may be easier than repairing it...just a thought...might could adapt 1 similar too...
Tommy Boy in PA
09-02-2002 18:04:49
 Re: Re: Open for suggestions..... in reply to wrenchman, 09-02-2002 01:13:08
Thanks for all of the suggestions! I actually have pinholes and a hole about the size of 8X15 inches on the top. All of these suggestions will help me in my quest for gas tank. Thanks again....Tommy Boy
Jerry S
09-05-2002 10:27:43
 Re: Re: Re: Open for suggestions..... in reply to Tommy Boy in PA, 09-02-2002 18:04:49
There are a lot of salvage yard with A's in them depending on where you are. A hole that big would be simplest to get another tank from the scrapyard. There is a salvage yard listing on ATIS.net site and more out there still. Green Maga$ine is a good site for advertisers who carry them. What year A? Where are you located?
