Carb tools
pat woodruff
09-01-2002 17:55:35
Does anybody know where I can find a screwdriver wide enough to fit the inlet needle seat?
Don Young
09-04-2002 22:23:26
 Re: carb tools in reply to pat woodruff, 09-01-2002 17:55:35
The carburetor manufacturers did make a lot of special tools but they are pretty rare. Making your own is your best bet. A nutdriver, socket, or socket extension make good raw material. Save your broken or worn out tools to make new tools!!
Joe (Wa)
09-02-2002 21:59:44
The smaller size lathe cut-off tool bits are a perfect fit and provide slip resistant torque as opposed to the vertical twist on a screwdriver.
Jerry in Id
09-02-2002 20:00:37
Thats why there are $.99 cents wood chisels.
Rod MI
09-01-2002 21:07:05
Try a Quarter or Nickel
chris
09-01-2002 20:19:02
of what type carb on what engine
pat
09-03-2002 17:33:35
 Re: Re: carb tools in reply to chris, 09-01-2002 20:19:02
Thanks for the ideas guys. There must have been a tool made to take the seat out though. The carb is a TSX 33. I guess I'll grind down a chisel or see if I can find the lathe bits.
Jerry S
09-05-2002 10:30:13
 Re: Re: Re: carb tools in reply to pat, 09-03-2002 17:33:35
Try robertscarbrepair.com for some tool prices. He does a lot of marvel sheibler carbs and sells tools to do them with. Might have something you need?
