Voltage Regulator
George Marquis
08-30-2002 17:01:15
I want to use a 100 amps automotive alternator driven by a small engine for back up power for my 36 volts electic vehicle.
Are there 42 volts voltage regulator on the market I could use.
Is there some one to advise me to built it myself( Plan, Bleuprint, Schematic diagram )???
George
Mike W
08-30-2002 19:30:18
 Re: Voltage Regulator in reply to George Marquis, 08-30-2002 17:01:15
I am not sure of the max voltage you can get out of an alternator. You could test by applying a variable power supply to the field winding. You may exceed it's rating and over heat it. 100 amps at 14v is 1400 watts. If the voltage was increased to 42, the amp output would drop to 33.3 to stay at 1400 watts.
You could disconnect the internal rectifiers and use 3 step up transformers to up the voltage. Then you would rectify back to dc. I would look around for a surplus generator to get the voltage you want.
