There are so very many variables, no one can ansewr you directly. If you are miles from any electric service right now, then a wind generator probably is cheaper than running in a service. You will need to manage your power consumption to match the gwenerator/wind output you have purchased. You would run with a battery bank & power inverter. If you are in one of the high-wind ridge areas (Parts of California & Minnesota have some great locations, as well as other regions) then you can put up a $2 million system & get your money back in a decade or less. Good investment, but _only_ if you have the right location. If you currently have power line service, and you are in an average wind location, it probably won't make you money, but you might wish to do it anyhow. It is possible your utility company, state govt, or fedral govt will assist you in getting a 'green' energy plant going, with grants or low-interest loans, which can make it worthwhile. Again, if you have the right wind location. You need to find out if you can sell power back to your utility company. You CANNOT just hook up & make your meter spin backwards... ;) Power companies will buy the power from you at wholesale rates, not retail. As well, you need safety interlocks so you don't fry a line repairman. (In Minnesota the utility is required to buy from you, don't know about other locations.) Here you buy power from the utility company at retail rates when the wind is slow, and sell extra energy to them when the wind is strong - use the utility company as your 'battery storage' place. The details & options of all this are many, many, and you will need to study up on it & research your own location & options & needs. ---Paul
