Cutting a weld
Tom
08-28-2002 19:36:14
What is the simplest way to cut a weld with a cutting torchor what ever. On a haybaler it has some metal panels that are rusted out and I wanted to cut them out and then cut a part and weld it back in place instead of the bondo repair. The metal is 1/4 inch thick (not sheet metal) or would it be better to grind out the welds or do they make a special tip to put on the torch for this? Thanks
TimC
08-30-2002 10:31:59
 Re: Cutting a weld in reply to Tom, 08-28-2002 19:36:14
A die grinder and cutting disk would work but might take a while if it is welded all the way around the seams.
Russ
08-28-2002 22:05:57
Hi Tom, If you have a Victor torch you can get a scarfing tip for what you propose. Seems like I`ve got one for a Harris torch too, but I can`t remember right now. Russ
