Cutting granite
Bert
08-28-2002 17:49:34
I have some granite curbstones 6"x18"
various lengths from 1-8'
I would like to cut them both crosswise and long ways for different projects.
I have had some luck using 2 steel mauls and a helper, but it takes a lot of pounding and some of the longer stones just won't break.
Can I use a 7" circular saw with a dry cut diamond blade to score/break these stones ? I can get 3 blades for about $40 but they are probably cheapies. Would I be better off renting a wet saw ?
Thanks for the free advice.
Jerry S
08-29-2002 07:25:05
 Re: cutting granite in reply to Bert, 08-28-2002 17:49:34
The construction guys here say they would go with a wet saw for a couple reasons. 1 you would burn up your 7" saw and 2 you have to cut it wet or will loose your blade quickly even with diamond blades. Besides, the wet saw takes loads less time.
