Portable welder standby power
Paul K.
08-22-2002 19:29:20
I have an older Lincoln 225 weldanpower portable with 3500 watt auxillary power. The spec tag says it is 50 cycle instead of 60 @ 120 volt. My question is will the 50 cycle do any damage to any electrical items I might use on this power source? Thanks
farmall300u
08-24-2002 10:45:10
 Re: Portable welder standby power in reply to Paul K., 08-22-2002 19:29:20
Typically, electrical appliances will run very hot on 50HZ vs 60 HZ unless they were designed to run on 50/60 HZ. Starting torque will be less on 50 HZ
Ralph, Ohio
08-23-2002 18:28:54
You may be able to speed up the engine to get 60 cycles or near to it. Just watch that the voltage doesn't go too high. Before microprocessors many appliances were labelled for 50 or 60 cycles and could be used on either one so check the name plates or specs. on what you want to power.
Sven
08-23-2002 12:23:07
First off any synchorous AC motor you run at 50Hz instead of 60Hz will run slower, refrigerator, freezer, fans,pumps, blowers. This may not actually hurt the motor but will effect machine performance. Resistive loads like lights and heaters wont care except for floresent lights which will flicker alot. Anything with a transformer will also be screwed up, most electronics all depends if they use the 60Hz for timming. In general for emergency use you might not damage anything but most things just wont be working properly.
Del
08-24-2002 05:02:03
 Re: Re: Portable welder standby power in reply to Sven, 08-23-2002 12:23:07
clocks will loose 10 min. every hour.Record players, tape players,CD's will run too slow and sound funny. Every thing else will be ok. Japan's whole country is on 110 & 220 volts 50 cycles.
