Drinking milk can't be overemphasized. Drink at least a glass of milk afterward. If you don't it will feel like the worst case of the flu you ever had, all your joints will ache. I worked on a temporary job once as a welder's helper building conveyors and storage racks in a freezer in a meat packing plant, and even as a helper it was necesary to drink the milk. As for the welder, they were using stick welders. If your welding store is competent, just ask them which kind of welding rod to use, and whether you will be welding horizontal, vertical, or overhead, and temperature. Grinding the galvanized off should not be necessary, and welding back over the weld may be necessary. We built storage racks with tracks on them to fill the center of a freezer 50 feet wide by 250 feet long along with all the conveyors and cat walks on 2 levels and across the ends, with no grinding. Drink milk afterward, figure out how you will have the part positioned, ask the welding supply store which welding rod you will need, and ask if there are any techniques you will need to know. Dennis Benson
