What is the difference between roll pin punch's and regular punch's?
R Wyler
08-13-2002 15:17:33
I am needing to remove a couple of roll pins and was told about roll pin punch's. What is the difference in them? And is it better to use them than regular punch's? Thanks. R Wyler.
thurlow
08-13-2002 19:08:07
 Re: What is the difference between roll pin punch's and regular punch's? in reply to R Wyler, 08-13-2002 15:17:33
Roll pin punch has a "teat" on end so it will center into and not distort roll pin.
R Wyler
08-13-2002 19:22:34
 Re: Re: What is the difference between roll pin punch's and regular punch's? in reply to thurlow, 08-13-2002 19:08:07
Thank you for the information I need to buy a set of them.
Ralph
08-13-2002 16:15:20
A punch used for roll pins is not tapered like most punches but is the same diameter for an inch or two so that it will fit deep in the hole. Also the end is flat so it doesn't expand the end of the roll pin as a pointed punch would do. The proper punch is slightly smaller than the diameter of the roll pin being removed.
R Wyler
08-13-2002 16:43:43
 Re: Re: What is the difference between roll pin punch's and regular punch's? in reply to Ralph, 08-13-2002 16:15:20
Thank you for the information I was curious about what they looked like.
bob
08-14-2002 05:15:39
 Re: Re: Re: What is the difference between roll pin punch's and regular punch's? in reply to R Wyler, 08-13-2002 16:43:43
punch is not flat on end but like a ball to self center. Its hard to do without one but have.
R Wyler
08-14-2002 06:43:25
 Re: Re: Re: Re: What is the difference between roll pin punch's and regular punch's? in reply to bob, 08-14-2002 05:15:39
I feel like it would problably be best to have a set of them. Thanks for the followup.
