Marquette Farm Welder
Diane
08-08-2002 12:56:27
I "inherited" an old Marquette Farm Welder but need to find the cable/cord to do the actual welding. Who handles Marquette Welders and where can parts be acquired?
T_Bone
08-08-2002 18:28:51
 Re: Marquette Farm Welder in reply to Diane, 08-08-2002 12:56:27
Hi Diane,
The welding cables are common amoung all stick welders and are multi-fit. I suggest 150amp leads as there easy to use than the heavier cables and 50ft would be good for a average shop. Most home shops don't use more than 150amps even tho they may have a 250amp machine.
Tweco makes the best rod holders and cable twist quick disconects if you want them. Cable disconects allow you to add more cable if needed.
All can be found on the internet or your local welding supply shop.
T_Bone
Diane
08-09-2002 07:28:54
 Re: Re: Marquette Farm Welder in reply to T_Bone, 08-08-2002 18:28:51
Thank you very much T_Bone.
