Air Compressor Tank Hole
Lee Cox
08-05-2002 20:59:31
I have a model 321 air compressor cast iron 2 stage with 80 gal tank. I was told the compressor is a Kellog compressor. The tank sprung a leak after twenty years. Everything still works well. Where do you buy tanks? Is it worth buying a used one?
David
08-08-2002 06:59:28
 Re: Air Compressor Tank Hole in reply to Lee Cox, 08-05-2002 20:59:31
Do not buy a used tank! Tanks can explode due to rust and age. You never know how much rust might be inside of that thing. Make sure you buy an ASME rated tank.
Mark-NC
08-07-2002 14:16:52
I looked for a reasonably priced one for a while and the best source I found so far is NorthStar. They are somehow affiliated with Northern, they build power washers, compressors, etc. In their catalog, they list an 80 gallon ASME vertical tank for $301.82 plus shipping. A word of caution, however, is this particular tank does not have a pump and motor mounting plate included. It comes with two standards that you can adapt your existing mounting plate to. Their number is 1-800-270-0810 if interested and that particular part number is PD35407.
Good luck.
cheapskate
08-06-2002 23:02:15
ya ever think bout lookin fer a condemed propane tank.propane is dry & tank wouldn't have any rust in it.should be fine fer an air tank after steaming er out & adding a drain.come in lotsa diferent sizes too.just a idea.
PeterS
08-06-2002 07:24:15
Grainger, give them a shot.
Ray,IN
08-05-2002 21:20:08
I would'nt waste my money on a used tank, most, like yours are neglected and corroded inside. A internet search will locate many firms that fabricate tanks. One close to me is Bruner Engineering, Bedford, IN.
