Concrete weight??
Steve
08-05-2002 19:30:24
Can anyone tell me what a gallon of dried Ready Mix would weigh? I want to fill my 55 gallon ballast box with cement. I don't want to much weight.I will be using this on a 25Hp John Deere 850 w/ cat 1 hitch. I was thinking a little less than 2/3 of barrel would do it. I want to figure out the weight befor I continue. Thanks Steve
JMS/MN
08-06-2002 21:29:59
 Re: concrete weight?? in reply to Steve , 08-05-2002 19:30:24
Rocks, gravel, concrete, etc. weighs about 60-70 pounds per cubic foot. Why not use gravel and rocks? Cheaper than ready mix, and easy to adjust the weight as needed.
T_Bone
08-05-2002 19:57:48
Hi steve,
1138lbs approx for 55gal filled to 33" or 150lbs/cft
T_Bone
About 19 pounds...n/m...Rod (NH)
08-05-2002 19:50:52
n/m
Steve B
08-06-2002 14:27:39
 Re: Re: concrete weight?? in reply to About 19 pounds...n/m...Rod (NH), 08-05-2002 19:50:52
What is n/m? Do you mean a gollon of concrete weighs 19 lbs?
Rod (NH)
08-06-2002 16:01:39
 Re: Re: Re: concrete weight?? in reply to Steve B, 08-06-2002 14:27:39
Hi Steve,
n/m is used as an abbreviation to indicate that there is "no message" to open...the answer to the previous poster's question is provided briefly in the "posted by" space along with the poster's name.
Yes, concrete weighs about 19 pounds per gallon...the answer to the question that was asked.
Rod
