Electrical troubleshooting help needed
James
08-01-2002 16:25:26
If I disconnect the output wires from my ignition switch and turn the key to 'start', I get a good reading of 12 volts. However, if I hook up the wire from the switch to the starter and turn the key to 'start', I get virtually no reading at all.
What could be the problem?
Bigdog
08-01-2002 17:27:37
 Re: Electrical troubleshooting help needed in reply to James, 08-01-2002 16:25:26
Check your battery cable connections. Both ends of both cables. Most likely a corroded connection at one of the posts or at the ground connection. With no current flow through the circuit, you will read battery voltage. with a load on the circuit and current flowing, most of the voltage will drop across the high resistance connection.
