Another have engine need project
ray
07-31-2002 10:09:18
Picked up two Ford FE 427's(V8)- (side oiler possibly-has the machining(?)). They came out of a 40foot Chris Craft. All the marine stuff is still attached (transmission,intakes,carb, alternator,etc). Thinking of moving one to a F-100. Anyone in the forum do something similar in the past?
Ray
Glenn(WV)
08-01-2002 06:30:30
 Re: Another have engine need project in reply to ray, 07-31-2002 10:09:18
I'd give my right arm to shoehorn one of those puppies in my T-bird!!! Awesome engines!!!
Don LC
07-31-2002 20:05:16
SIDE OILER 427 FORD ENGINES ARE SOUGHT AFTER BY THE HOT ROD GUYS.....THAT IS THE ENGINE CAROL SHELBY USED IN HIS WORLD FAMOUS RECORD SETTING COBRAS----THEY SURE WOULD BE WASTED IN A TRUCK....
Mark
07-31-2002 16:19:50
If I were you I would advertise them in Hemmings Motor News. Those motors are worth $2500-$3000 each to a Ford collector if they are complete and not cracked.
Bob
07-31-2002 14:55:24
I think all you have to do to make the backwards one run the other way is a proper camshaft and oil pump drive gear, and the appropriate water pump. That's how it is on the Chevrolet engines used in a twin, counter-rotating arrangement, and can't imagine it's too much different on the Ferds.
Errin Oh
07-31-2002 11:02:04
In most marine aps one notor will run clockwise and the other counterclockwise. One should be contervertable, the other most likely will be rotating the wrong way.
ray
07-31-2002 11:20:49
 Re: Re: Another have engine need project in reply to Errin Oh, 07-31-2002 11:02:04
Yep. Thats correct. I'm stumped at the moment as to what to do with these motors. They were headed for recycling. Wife thinks I'm building a post and beam barn out back. When she hears the air tools tonight ...
Neil
07-31-2002 12:47:17
 Re: Re: Re: Another have engine need project in reply to ray, 07-31-2002 11:20:49
Maybe someone with a boat would like the pair. Seems more likely than findinga good use for them the way they are now.
Errin OH
07-31-2002 14:12:38
 Re: Re: Re: Re: Another have engine need project in reply to Neil, 07-31-2002 12:47:17
Yea, thats what you should do with them. But sell them as a pair. That is if'n they'r rebuildable. I know many a marina that buy these thing up just to sit on a shelf untill some poor unsupecting boater needs them. Oddly enough, then there the only ones within 200 miles and made of gold.
Thomas Rodgers
07-31-2002 22:36:07
 Re: Re: Re: Re: Re: Another have engine need project in reply to Errin OH, 07-31-2002 14:12:38
I have a riding lawn mower that could use a boost...
ray
08-01-2002 08:43:18
 Re: Re: Re: Re: Re: Re: Another have engine need project in reply to Thomas Rodgers, 07-31-2002 22:36:07
Ends up I'm stripping them down to the blocks and putting in storage till I find a truck to put one of them in. Want something with some pulling power. Thanks for the replies.
greg
08-03-2002 18:47:43
 Re: Re: Re: Re: Re: Re: Re: Another have engine need project in reply to ray, 08-01-2002 08:43:18
Remember one thing: These are YOUR engines now. In my opinion, as long as you don't butcher the castings, you should put them in and use them any way you see fit, just have fun with them. Even if you put them in a high performance wheel barrow, the only way these engines would go to waste would be to have a collector set on them for forever , forget about them, and someone's estate scrap them because they didn't know what they were. These engines (esp the marine applications) were made for torque, and to have fun with. Get 'em going, and have a ball, you may never find another. When you are tired of them, then part with them.
Joe
09-06-2002 18:48:10
 Re: Re: Re: Re: Re: Re: Re: Re: Another have engine need project in reply to greg, 08-03-2002 18:47:43
The counter rotating motor's crank seal surface is different and will destroy the seal if ran clockwise. I think it can be machined to run the other direction. If I'm correct these blocks were cast side oilers but were not drilled side oilers 40 ft boats don't turn 7000 rpm and all that crank oiling isn't needed. I would like to know myself if these blocks can be drilled as side oilers?
