John deere A
Mike Green
08-20-1998 11:06:36
Not getting enough gas. Carb has been rebuilt. Gas tank is in great shape. Air cleaner is not clogged. Vacuum lines? Also, where
in the heck is the serial no. on this tractor
Tom J.
08-21-1998 00:17:18
 Re: John deere A in reply to Mike Green, 08-20-1998 11:06:36
: Not getting enough gas. Carb has been rebuilt. Gas tank is in : great shape. Air cleaner is not clogged. Vacuum lines? Also, where
: in the heck is the serial no. on this tractor
The problem might be with the float. The float adjustment is 1/2" below the top of the bowl on most models. Also there is a screen in the top of the sediment bowl on the tank. There are no vacuum lines. The serial number will be on a metal tag riveted on the block under the magneto. Good Luck. Tom
