Russ
07-31-2002 19:37:06
Re: Tree Jacks in reply to Tim B, 07-29-2002 20:17:52
Hi Tim B, you haven`t said much about any lean other than you wouldn`t be felling much against the natural fall line, so I`m assuming the trees are pretty straight. Are the limbs balanced pretty well or are they going to pull the trees where you don`t want them? If you are not fighting anything too extreme, wedges and a good hinge should do the job. Are you familiar with bore cutting the hinge? This method gives excellent directional control because a good hinge can overcome many other forces. First you take your time and make a nice clean, large face notch in the direction of your intended fall, use your felling sites if your saw has them, then make a plunge cut about an inch or two above the base cut of the face notch, parallel to the V formed by the notch, just like you would want to end up in a traditional felling cut. Get your hinge nice and square with parallel sides, 2 1/2 to 3" thick. You can take your time making a nice clean hinge because the tree is still supported by most of it`s diameter. Once your hinge is what you want it to be, cut backward away from the hinge until you are 3-4 inches from cutting out, now pull the saw out and drive in a bunch of wedges, drive `em in good and hard. When the wedges are in, make the back cut just like normal and the tree goes down where you want it. This method also gets you away from the business end a little quicker and prevents barberchair. I looked at the link for the jacks you asked about and I`m a little skeptical. Have you seen them in use or know anyone who has them? Silvey is the brand that I`m familiar with, and some loggers felling incredibly big timber swear by them. They are a few grand for a set though. It used to be that Bailey`s would rent or lease equipment, maybe that would be an option for you if you want jacks. BTW, my description of this technique probably leaves something to be desired, make sure you fully understand it before you try it. Oh yeah, and don`t forget the wind. Russ
