Air conditioning
keno henderson
07-28-2002 09:27:53
Off topic. Sorry but you all have never let
me down yet.I'm on vacation at the lake and my
air conditioner(in my cabin) is freezing over.All doors and
windows are closed.I think its low on freion?.
My question is what kind of freion is used.
If I just add a can or two untill Monday when
I can call someone.Ok someone make me a hero.
Thanks In advance [email protected]
RayP(MI)
07-30-2002 18:40:16
 Re: air conditioning in reply to keno henderson, 07-28-2002 09:27:53
I had a similar problem, with an airconditioner "freezing over", Turned out the thermostat located in front of the cooling coil had quit, and the thing had turned into a freezer! That thermostat is designed to cycle the compressor off before it freezes over. Might want to observe the compressor and see if it cycles properly before adding freon.
Ben E.
07-28-2002 12:38:52
It could be a little low on freon. But if you have not been having to add freon in the past I would suspect a clogged air filter or the evaporator coil needs to be washed out. The most common cause for icing is lack of air flow thru the evap. coil. After checking and cleaning and proving ample air flow you must let fan run with compressor off till ALL ice is gone before restarting compressor or the ice will form right back again. Should wash dirt out of condenser coil too. Don't forget to turn the electricity off before washing anything tho!!
Good luck
Ben E.
T_Bone
07-28-2002 14:52:25
 Re: Re: air conditioning in reply to Ben E., 07-28-2002 12:38:52
Hi Keno,
Freon is a Dupont trade name. Refrigerant is idenifiyed by numbers R12, R22, R500 etc. Depending on how old your condensor unit is theres new refrigerant to replace the now outlawed refrigerants, R12 and R22 at which yours is probably R22. There is a direct replacement for R22 but it's not available without a license.
Mixing two different refrigerants will do nothing more than cost you more to have it fixed correct "if" that is the problem.
Ben gave you some good pointers to look for. A hair dryer works well for defrosting the evap coil. There again you working with water and electricity so be extreamly careful.
T_Bone
greg
08-03-2002 18:58:52
 Re: Re: Re: air conditioning in reply to T_Bone, 07-28-2002 14:52:25
If its freezing over, then you don't need anymore refrigerant, its just doing what the thermostat is telling it to do: COOL. Check 'stat, airflow, etc, like other guys suggested. Then call for help-its worth it.
