Hi Ford Man, That is a good rule. Dials are a guess-o-ment of where to set a machine for futher refference. 130amp setting on mine might be a 135amp setting on yours. When having any problems with any type of electrode always start at higher amps then start cutting down amps when you see problems from too much heat, ie; flux pre-flaking off the electrode excessive weld splatter loose of weld puddle control Most of the above can be corrected with arc length and travel speed BEFORE turning down amperage. A close arc length will give extreamly good weld puddle control and contour. Type of steel, moister content, humidity, cleaned joint or scaled joint, mostier content of the electrode, will all effect at what temperature a weld puddle is at. Temperature not being a refference to numbers but as to molten flow of the weld puddle. Hard to beat Chemtron 7018. That is the finest all around electrode I've ever used. Lincoln P5 or 6010 is another excellant electrode. These are brand specific rods. Other electrode brands will not weld the same. 1/8" is a good size. I have been known to carry a very hot weld puddle but one time I was taking a certification test and the test instructor did a 3/8" vertical plate test while I was there. That man carried twice the heat that I even considered. At the time I didn't think anyone would weld hotter than me. T_Bone
