Hi Rod, Sounds like you have some serious welding to do as 200amps Tig will require a wet torch, coolant circulation with-in the torch head. A dry troch is max about 90amps and 125amps for short welding times, about 15min with 15min rest. Very few times while welding did I require a wet torch but they are nice as it does keep the torch head cool. Weld puddle control best comes from the smaller 90* torch with 150amp lead. If your going to be welding alot of deep groove pipe joints then a 75* head works well for rocking in the weld with a #10 cup. Most projects will Tig welded in the 90amp or less range so thats why I suggested the smaller torch. If you were going to need continious high welding amps then a I would buy two torch sizes as you will not like the larger torch head while welding the general all around shop items. Tweeco makes the best welding products for any type of welding. I would think you would be looking at a #8 wire and your going to be limited with a dryer receptiable. I would run a dedicated circuit. Are you sure you want or need a 275amp Tig machine? Although it generaly requires you to buy a higher amperage machine to get all the "goodies", most of my welding comes in the 150amp or less range even while welding full time. T_Bone
