Cyclone Hand Crank Seeder
David
07-26-2002 05:36:50
Does anyone know if replacement bags are available for Cyclone Hand Crank Seeders? I have not seen one in years. The bag on mine is starting to tear. Thanks!
John in Md.
07-27-2002 05:35:22
 Re: Cyclone Hand Crank Seeder in reply to David, 07-26-2002 05:36:50
Clover seed bag fit mine just right.Took old bag off and kept the edging material off of old bag ,cut bottom out of seed bag and stapled everything back together.Don't know if you can get cloth seed bags in your area,but a bushel clover bag worked for me.
hay
07-27-2002 04:04:34
i have had a cyclone seeder for more than 20 years. to help perserve the bag, i spray it with silicone waterproofing spray that i get at wal-mart sporting goods dept. throughly soak the bag inside and out and let it dry before using. after washing out the seeder a few times, give it another soaking of the silicone spray. then about once a year i give the bag a light coating.
John
07-27-2002 01:55:47
Take the old bag off to use as a pattern & make a new one out of dennim ( jeans material ). I did one about ten years ago & still going strong. J.
Pcc-AL
07-26-2002 15:24:07
Hi David,
I have a Cyclone seeder hanging in my old corn crib. I haven't used it in 20 years and I'm sure the bag on it is gone too. I recall once I replaced the bag with a flour sack. If memory serves, it worked pretty well. You may have to take out a little slack when you attach the bag to the seeder. Good luck.
Wllem van Heerden
01-03-2003 08:20:58
 Re: Re: Cyclone Hand Crank Seeder in reply to Pcc-AL, 07-26-2002 15:24:07
A friend of mine was given a hand cranked cyclone seeder, manufactured by the Cyclone Seeder Company Inc,Urbana, Indiana USA.and it work so well we are both looking for another two. Can any one help? We are farmers (cattle and horses mainly) in South Africa and do have to plant small (4-10 ha) of grazing from time to time.
Any assistance as to where I can try to buy such seeders will be much appreciated.
Kind regards
Willem
