Repair compressor air hose?
Chuck, WA
07-24-2002 06:31:29
A couple of nights ago while building my barn and using a nail gun, the connector on one end of the air hose that had been leaking finally blew out. It's a swaged fitting. The swaged collar is still on the hose, but the connector blew out of it.
What's the repair on this? Is it OK and safe to cut the swaged collar off, reinsert the connector and use a hose clamp to secure it? Or is it necessary to take it to a repair place and have a new swaged fitting put on? These days, at $50 an hour and upwards with half-hour minimum, I'd guess it's a tossup to repair or buy a new hose. A hose clamp would sure be preferrable, but not if it's unsafe. The comnpressor gets up to about 120 psi, and for the current work on the barn, the nail gun is running at about 110 psi.
Thanks for your advice!
JohnnyB
07-25-2002 14:43:47
 Re: Repair compressor air hose? in reply to Chuck, WA, 07-24-2002 06:31:29
Good grief, it's a $2 repair. Cut off a couple inches of hose, slip it back on and screw on a hose clamp, heck put two on if you have any doubts.
Leroy
07-25-2002 04:48:51
The repair kits come with the hose clamp
John in MA
07-24-2002 08:42:38
I just use hose clamps for this. One of my air hoses is 50 years old. A little shorter now, but still doesn't leak.
Mark Kw
07-24-2002 06:53:47
If this is the only hose you will likely ever repair, I'd suggest just buying a new hose for under 20 bucks and be done with it. You can use a hose clamp, I've done it as have many other but there is the safety issue because they don't hold for long and will get caught up on everything in sight.
If you have several hoses and plan on keeping up with them, you can get the ferrules and barbs to match at most industrial and hydraulic supply houses. Crimpers for them come in a variety of fashions from Channel Lock brand pliers with crimping jaws to table top slide arms with various size jaws to high priced electric hydraulic set-ups. The slide types are the best for normal shops since they run about $25 to $80 depending on size/type. These will do a variety of sizes while the Channel Lock ones will do only two sizes.
You have another option which is screw on connectors. These have an outer ferrule that screws over the hose and an inner barb that screws into the hose, as they are tightened, the seal is made. These can be used over and over again and are the best choice for someone looking to do only a few hoses and does not want to invest in special tools and fitting assortments. These run around $6-9 each for 1/4" and 3/8" hose and around $11-15 for 1/2" hose. You can get them with QD coupler ends or NPT threaded ends, also available at most professional auto parts shops as well as places like Fastenal, Grainger, MSC, ect...
Craig- some stores can repair your hose
07-25-2002 07:36:56
 Re: Re: Repair compressor air hose? in reply to Mark Kw, 07-24-2002 06:53:47
Our local NAPA store has new crimp sleeves and fittings in stock. You might also find a good hardware store with the same stuff in stock and offering this service.
Just a month ago I had the end of an old hose go bad. I cut off the hose end, removed the old fiting and took it to NAPA. The new crimp sleeve installed on my old hose and fitting was a whoping 83 cents. Now I'll be good for a few more years.-
Greg AZ
07-25-2002 07:09:27
For five to seven bucks a new hose can be purchased at Harbor Freight or Home Depot. Why would you spend 100 dollars or more on widgets and doodads to make an old air hose work, when it is sure to fail in a short time? It seems like buying a new hose is the best deal in the long run. Nothing more annoying than a leaky or exploding air hose. All the best..... .Greg
Chuck, WA
07-24-2002 07:33:03
Mark...Thanks! Exactly the kind of information I wanted. this is probably a one time deal, so I'll probably look for the screw-on connector you describe in the last paragraph.
Jet9N
07-24-2002 21:04:17
 Re: Re: Re: Repair compressor air hose? in reply to Chuck, WA, 07-24-2002 07:33:03
After repairing the hose with the hose clamp turn
the hose end for end. Very likely the other end is just like new. That way you don't have to put up will the hose clamp on the end next to the tool you are using.
HTH
Jet
