Lincoln AC 225 welder
kevin
07-24-2002 05:46:26
Need some help on replacing the cooling fan motor on this machine. Mine quit working. Removed the old one and ordered a new one. Sketched the wiring arrangement on a scrap piece of paper and now I can't find the sketch. It's only got two wires and I remember at least one lead was on the switch and the other lead tied in somewhere else.
If anyone has one of these machines with the cover off (down here we call 'em crackerboxes), would appreciate some help. I don't want to burn up my new motor.
Thanks,
Kevin
Steve U.S. Alloys
07-26-2002 09:01:41
 Re: Lincoln AC 225 welder in reply to kevin, 07-24-2002 05:46:26
You'll probably get the info you need with the motor Kevin..... if you ordered an OEM replacement.
kevin
07-26-2002 10:39:16
 Re: Re: Lincoln AC 225 welder in reply to Steve U.S. Alloys , 07-26-2002 09:01:41
Steve,
No wiring data was received with OEM package. However, the problem has been solved. I had taken a couple of digital photos before I disconnected the wires. Was able to determine correct connection details from the photos.
Thanks for the reply though.
Kevin
