Hi Mark, I'm not making my point clear enough. Here is a quote from Smith welding; "Every manufacturer publishes recommended pressure settings for every tip, based on the gas consumption of the tip" Yes the tip orifice can flow "maxmium" gas at the designed flow rate but it's the regulator that regulates the flow to the tip. Flow can be futher regulated by the needle valve on the mixing chamber. For example ONLY: DO NOT TRY THIS ON ANY TORCH! Lets remove the regulator and the mixing chamber from the system. We now have a acetylene tank at 250psi with a 3/16" hose connected to a 30cfh tip orifice. What controls the rate of flow? The tank valve in this example although extreamly crude. Now if the tank valve is fully opened then the tip orifice rate of flow is limiting factor. Now lets add a regulator to the tank. What controls the rate of flow? The regulator does. As the regulator pressure increases so does the flow rate. With tank valve opened 1/2 turn, barely open the regulator valve to 1/2psi and the rate of flow will be very small thus shown by the low flame size. Open the regulator to 15psi and now the flow is increased as shown by a very large flame size. Now lets add a mixing chamber. Regulator set to 5psi. What controls the flow? The needle valve. Open the needle valve wide open. What controls the rate of flow? The regulator! I never exceed the safe limits of acetylene. It's just not needed nor do I recomend it. T_Bone
