2x8's are secure to the block, actually will be replacing the existing ones with new ones. I wasn't fond of the swing door idea until I saw it done on a retail store front. Granted theirs are production models made from extruded aluminum but it works great for them. I called the mfg of these and the price is totally out of the question, for similar set up to fit my sizes $8250!! I need as much of the opening as I can get, plan on taking pick-up trucks and cars in and out as necessary when the other bay is tied up. Header is plenty strong, 8" steel beam, but having the overhead swing on either inside or out will cause logistical problems loading and unloading items from trucks. I ran all the options and the swing doors are what will work best for the least cost and time investment. I don't plan on being here much longer so I don't want to get into serious changes and costs. Thought about installing the threshold over the 2x4 but didn't think about the osha factor, should be easy enough to do this way. For anchoring the hinges to the 2x8's, should I just use stainless steel wood screws or put a steel plate on the back side of the wood then use self tapping 1/4"-20 screws to attach the hinges? Don't want to have trouble with loose hinges/screws. How about weather strip/stops? Saw numerous types of these, extruded AL with U shape vinyl and also foam rubber for the seal. Price is reasonable either way, more concerned with what will work better. Going to loose some heat no matter what I do but I'd like to keep the losses as low as possible.
