Ford 2000 carb
Robert
07-17-2002 09:29:13
I'm pretty sure this has been a topic on this bord before. Well here goes I'm a new tractor owner or first owner time anyway, I picked up a sweet deal on a early ford 2000 got the engine rinning with little effort but the problem that I'm having is when I select a throttle setting above idle she spits an sputters and will evetually stall.
This is nerve wrecking becaouse it Idles and runs beautifuly. the problem is just as you come from of idle setting. If anyone is wondering yes the cab has been overhauld and it is taking adjustments. If anyone else has seen this problem and has a solution please do tell.
Thanks.
