: : : : I am seeking advice/experience with using JB Weld to repair a key slot on a : : : : shaft. : : : : Background: : : : : This is on an IH Model 100 sickle bar mower. The drive pulley on the balanced head : : : : was broken off from it's center and rewelded by the PO which eventually : : : : selfdestructed. Most of the damage was in the pulley, but the shaft has some : : : : minor damage basicly elongation of the slotted keyway side to side. I have : : : : checked on replacement parts which surprisingly are still available, but : : : : lets say the term "cost prohibitive" would be an extreme understatement. : : : : So I am looking for the best way (read cheapest/quickest/easiest, you get the : : : : idea) to put this thing back together. I have found a good pulley which goes on : : : : OK and holds with just hand pressure turning the pulley, but before I put any : : : : stress on it I would like to build up the area on the sides of the key slot. I : : : : was thinking of using JB Weld but don't want to just goop it up and glue : : : : together permanently (the thought of ever having to get it off again is not : : : : entertaining). Does anyone know of a release agent like wax paper, grease, : : : : ..etc that I could put on the key or maybe between the pulley and shaft so that : : : : I could apply the JB Weld to the shaft and then tighten the pieces together to : : : : form a mold? : : : : Thanks for any ideas, : : : : Stan(VA). : : : Maybe something like Saran wrap around the key, fill gaps with the J-B ,then dress any excess with a file. Good Luck. : : : How about this: Coat the splined shaft with some type of release agent, ie. spray paint or vaseline, and set in a mold of plaster of paris. Remove when set by tapping out, then use this new mold to cast an input shaft out of some more plaster of paris, or a rubber compound. Use this plaster or rubber input shaft to create the keyway with JB Weld in the original piece. When it is set, chip out plaster shaft, or burn or melt out rubber one (if it does not come easily). Then, use original shaft in the new keyway. May be too much work, but look on it as an adventure in frugality. John. : Thanks for the input guys. I thought about welding, but pulling that ballanced head assy apart looks like a pain in the neck (and the wallet). Under the circumstances I think the saran wrap approach will be the most reasonable. But John, you certainly get honorable mention for originality! : Stan. There are several machinists in the dakotas and neb. who do tis type of work. and then it will last. you will be lucky if it lasts 3 min.
