Greg, I am in no position to debate your personal experiences, but I will point out that incomplete or misleading information can lead misconceptions. While I suspect nothing I can say will change your views on the subject, I'm going to address some of your remarks for the benefit of anyone else that's interested. "in the 1950's and '60's, white gas was indeed unleaded gasoline".....yes it was gasoline, and yes you could use it in an engine. But, it did not contain the many other additives that modify and improve gasoline for use as a motor fuel. "automotive gasoline would foul the ports in two cycle engines".....lead doesn't foul ports, but 2-cycle engines demand a lot of their spark plugs and ignitions. During the era you site plug fouling in 2-cycle engines was an even bigger problem than today. Running unleaded fuel helped by eliminating lead fouling "an inch and a half of "gray goop" in the bottom[pan]. These deposits are pure lead".....these deposits are not pure lead, lead would be only a trace element "lead and "lead additives" actually do more harm than good, that lead is a contaminant rather than a blessing"..... Lead was not a contaminant, it was intentionally added to gasoline to allow higher compression/power. Running engines that need this octane on lower octane fuel requires modifications and/or adjustments that reduce power output. Lead was not, as you seem to suspect, part of some scheme to get-over on the public. "oil pans, full of oil, actually rusted and pitted from these deposits[lead]".....In most environments coating steel with lead actually helps protect it from corrosion. If lead was the culprit, cars made after 1975 would no longer experience this ongoing problem. "modern three angle valve jobs".....a three angle valve job will in no way compensate for the absence of lead, as I have previously pointed out, its a temperature/materials issue Buicks, Super 88 Oliver.....if you have experienced no valveseat problems using unleaded fuel in these engines you are obviously not exceeding the critical temperature for the valve/seat materials. As I tried to explain previously, that is the key. However, just because you haven't had a problem doesn't prove that lead wouldn't prevent seat erosion in another application. And, neither does it prove that lead does "more harm than good", or that lead is "a contaminant rather than a blessing". Valve rotators.....although the true worth of valve rotators has come under some suspicion in recent years, the article indicated they accelerated seat wear in engines already experiencing seat erosion due to absence of lead. The claim was not that rotators promoted seat wear under "normal" conditions. If you'd like to respond I'll let you have the last word on the subject. Thanks for keeping me on my toes...Al English
