Plasma cutter
gene gullo
07-05-2002 11:11:48
Has anyone used a plasma cutter to cut 3/8 thick cast Iron. I want to cut a tractor transmission in 1/2. Do you think a plasma cutter would do this neatly? What size would I need? Any tricks to learn?
Al English
07-05-2002 21:12:29
 Re: plasma cutter in reply to gene gullo, 07-05-2002 11:11:48
Provided the machine is big enough for the material you are cutting, a plasma cutter will cut iron with no problem. The edges immediately adjacent to the cut will be hardened by the cutting process, but this hard zone can be removed with a grinding stones or abrasives. If you will be cutting through any ribs, webs, flanges, or other areas where the material thickness varies, the cut will tend to drift/divert away from the thick section and toward the thinner area. The neatness of the cut depends on your steadiness and technique, and the type and thickness of any variations in the cut line. In any case it's not going to be as nice as if it were sawn or rough machined. If the cut must be accurate, and significant thickness variations will be cut, I wouldn't trust the plasma cutter to make a straight cut. Good luck...Al English
