Electic shock from welding
Bill Vt
06-26-2002 18:49:28
I've been reading the manual from my new miller 225 stick welder that I haven't used yet and one paragraph says... " Insulate yourself from work and ground using dry insulating mats or covers big enough to prevent any physical contact with the work or ground".
I've always been aware of the danger to the eyes from arc rays and if anybody is around I warn them.
My question to any experenced welder reading this post would they please share some knowledge about the dangers from electric shock.
Gordon in IN
06-30-2002 21:26:32
 Re: Electic shock from welding in reply to Bill Vt, 06-26-2002 18:49:28
In addition to "shock" you might also want to be concerned with the "inductance" or "magnetic field" generated between the two power leads (the electrode lead and the ground lead). "Lincoln" gives a good explaination of this in their cautions and safety advisories. If you position yourself (your body) between these two leads while welding you are asking for trouble. This may not be a short term problem or even noticable. It can and will be a long term problem. The old practice of draping the electrode lead over your shoulder while welding is "very bad". I like to follow the advice from "Lincoln" and tape the two leads together up to about three feet from the electrode holder. Also keep the leads away from you while welding. There is some claim that the occurance of heart trouble for arc welder operators is "much" greater than other professions. There seems to be something ready to "get us" everywhere we go or whatever we try to do. You might want to check the safety advisiories from your own equipment manufacturer. Just trying to help and make welding a little safer, Gordon in IN.
Little Ed
06-30-2002 09:15:58
The way it was explained to me, it only takes 1/10 amp to stop your heart. If you are getting any tingle at all you are getting closer than you want to be to getting electrocuted. Dry boots and dry gloves are essential. If you are in contact with what you are welding on, put down something to act as an insulator. I change my gloves, shirt, jacket, boots,etc. when I start to perspire. I do a lot of TIG, and the high frequency is about 10,000 volts, no amps until the arc is established. It always seems that DC is only a slight tingle, while AC is a full fledged jolt. I always figured that was just the difference between AC & DC and tried to insulate myself from all chance of shock.
bbott
06-28-2002 20:44:55
I've been 'bit' on quite a few occasions. Worst was welding wet under the hydraulic (water jet) debarker in a sawmill.
Not a real pleasant thing and gets your attention, but I've been hurt worse.
That said, taking a few minutes to be safe won't hurt a thing (sounds like a safety slogan?).
Dry gloves + dry pad to kneel/lay on and you'll never have a problem.
Shortcuts = Accidents.
MarkB
06-28-2002 10:37:37
Just three things not already mentioned:
1. Any voltage over about 40 volts is potentially dangerous; your skin is a good enough insulator that lower voltages generally won't shock you. Certainly any welder can generate enough voltage to hurt you under the right conditions.
2. DC power at a given voltage is generally more dangerous than AC because AC tends to travel on the outside of a conductor (your body in this case), while DC is evenly distributed through a conductor.
3. Welders are highly inductive, so they tend to generate voltage spikes when you interrupt the current through them. (Just like an automotive coil.) So when you break your arc, the voltage from the welder can momentarily spike to several times its steady state voltage.
Fred OH
06-28-2002 09:07:24
It's always fun to get shocked and burnt at the same time, reaching for the stinger while eyeball engineering the job at hand. I prefer to do it early in the morning and call it wake up call. Shop welding on a concrete floor will generally just tingle you a bit, but I firmly believe it would make a preacher learn how to swear. But, on the other hand, if you are outside the shop on grass welding up "I" beams that are too long to be welded in the shop and using 1/4" rod with the welder turned up to three or four hundred amps, that is a horse of a different color. It will light you up like a christmas tree. The use of a rubber mat and dry gloves keep you from cussing so loud that your grandmother will hear you. Make sure that you have a good grounded 240 volt system to hook the welder to and wear extra protective clothing when welding at high amperages. Don't be affraid of it unless maybe you are wearing a pacemaker, you'll learn to live with it or quit, one or the other. I was once burnt and shocked in the side of the face while reaching back under a weld bench to change the tap on an old A O Smith (round type) welder when I was a young man and the hole it burnt in my face is still there. If I saw one of those old welders today, I would go the other way. Always use a dry glove when changing rods, it will keep you from being the path of least resistance. Keep your welding equipment modern, don't put much faith in real old stuff, The insurance tables used to say that the welders had the highest rates of skin cancer and lung cancer. Your mileage may vary, may not too! L8R....Fred OH
JD720
06-28-2002 08:42:13
Think of it this way: you know those little stun guns used for self defense? They have very high voltages 50,000 v + but very low apmerage. They will throw the muscles into spasm. Remember that the heart is a muscle and it is a heart attack that will kill you from high voltage low current (in the thousandths range as in way less than 1 amp). High current on the other hand will cook you. If there is enough conduction through your body or appendage the curent will cook you along the path of current flow. Any voltage that interupts the heart can kill. Recent article - a man was found dead with the probes from an ohm meter stuck in his thumbs. The investigators speculate that he was attempting to check his resistance and aparantly the probes contacted the blood stream and shocked the heart. The ohm meter uses a small current and voltage to check for resistance and that was enough to stop his heart.
Little experiment: what is needed:
1 lamp cord with plug intact
2 nails 6d to 10d (doesnt need to be a rail spike)
electrical tape non conductive surface near an outlet (scrap of wood)
wire strippers
take a lamp cord (with it unplugged cut it a couple of feet long and strip a couple of inches of insulation off.
Next wrap each wire around the nails near the heads. Next wrap the wire and nail with electrical tape leaving 1 inch of the point of the nail uncovered.
Take the hotdog and instert the nails in opposite ends.
Place the hotdog on a non-conducive surface and plug the cord into an outlet. In less than a minute you will have a very "hot" hotdog. Remember to unplug from the wall before touching the hotdog.
also disassemble the device when you are finished wouldn't want any children hurt by it.
Remember this is only around 10 to 15 amps at 110v.
RHOUSTON
07-01-2002 12:13:17
 Re: Re: Electic shock from welding in reply to JD720, 06-28-2002 08:42:13
now be careful you'll have Al English hooking his tongue up to his multimeter. And then you'll owe him lunch too. !!!! I argued the finer points of electrocution with him to no avail.
Point is no electrical current running through your body is healthy. whether you feel it or not.
I saw the previous posts as an article while looking for info to support my claim a few posts down, but didn't dare post it.
Wonder when the electric exercise devices will see lawsuits for some muscle tick it caused.
Or when we start to see health effects from all the RF devices comming into use in the home. After all RF ID uses current from the RF signal to power its chip. power enough for it to radio back its info.
Jim WI
07-02-2002 10:28:24
 Re: Re: Re: Electic shock from welding in reply to RHOUSTON, 07-01-2002 12:13:17
"Point is no electrical current running through your body is healthy. whether you feel it or not."
Oops -- now who's talking in absolutes?
One technique I've heard of for improving healing of badly-broken bones involves passing small electrical currents through the area.
rhouston
07-02-2002 11:49:36
 Re: Re: Re: Re: Electic shock from welding in reply to Jim WI, 07-02-2002 10:28:24
you got me there....
guess I've been shocked once to often(probably 6 volts), and now I've become overzealous and muddied up a good post
jrhine
06-27-2002 20:57:06
a dc welder will rattle you if you are grounded sweaty or wet but not enough too hurt you.
Jim in Michigan
06-27-2002 20:05:25
One thing that I have found is a No No is to replace a stick while kneeling on the ground,,wet or dry, I have been sparked pretty good from doing that,,,,Jim
bob
06-27-2002 20:47:58
 Re: Re: Electic shock from welding in reply to Jim in Michigan, 06-27-2002 20:05:25
local kid was killed by welding on his motorcycle, barefooted, in the grass. The slight wetness on the grass from the dew killed him next to his mother's back porch. Welding equipment is not there just for good looks.
redrev
06-28-2002 06:49:54
 Re: Re: Re: Electic shock from welding in reply to bob, 06-27-2002 20:47:58
No wonder I don't weld!
Jim
06-27-2002 17:17:34
I ran into a situation a few years ago where got a real jolt from a stick welder. After a little dective work found that when the contractor built the building (as in winter in northern Minn. he had frogten to put the ground rod in for the service we had him back and installed ground rod and no more probles even with water on the floor from the dripping trucks. just me 2cents worth
Cubub
06-27-2002 17:11:39
Here's some experience of weldors. Not many of these guys were electrocuted, some were. But atleast 60 Miners/Weldors were killed, one at a time, over past 7-8 years. A guys just gotta pay attention to the details, and then sometimes the obvious.
Go here:
Link
then in the "Search" box, type in welder
Steve U.S. Alloys
06-27-2002 06:05:52
Hello Bill,
It's not the voltage that you need to worry about, it's the amps that kill.
Most who receive a shock from their welder have not properly connected the ground clamp. The clamp should be as close as possible to the area of the weld and connected in a place that was ground clean. The ground clamp itself should be periodically inspected to ensure that the cable is seated properly in the clamps base with no excessive fraying. If the clamp surface contacts are compromised by spatter build up this should be removed. A bad ground can easily be detected as the clamp will get hot if resistance is present.
Both cables, ground and electrode, should be inspected for cracks in the insulation. The electrode holder should also be inspected for good cable connection with no excess fraying.
In short, electricity takes the path of least resistance. Make sure it isn't you.
HTH,
Steve
Hi Steve
06-27-2002 06:37:56
 Re: Re: Electic shock from welding in reply to Steve U.S. Alloys, 06-27-2002 06:05:52
I have no issue with your basic advice, but there's one thing I'd like to clarify. 1000 amps at 6 volts will not kill a person under any real world circumstance. However, less than one percent of that thousand amps(10 amps) at 110 volts can and has killed many people. While it is true that exposure to high voltage/low current(very low) power can be tolerated without any apparent affects, I wouldn't want someone to get the impression there is any inherent safety associated with high voltage power sources. Thanks...Al English
RHOUSTON
06-27-2002 09:23:58
 Re: Re: Re: Electic shock from welding in reply to Hi Steve, 06-27-2002 06:37:56
1000 AMPS AT 6 VOLTS WOULD KILL YOU !!!!!
have you not heard of anyone being electrocuted under the dash of a car ??? a liitle sweat and 80 amps at 12 volts is all it takes. worse yet its DC. does not happen often but it happens
Al English
06-27-2002 16:51:19
 Re: Re: Re: Re: Electic shock from welding in reply to RHOUSTON, 06-27-2002 09:23:58
Hi RHOUSTON,
As Nolan indicated, 6 volts is not enough to do anything. I will personally put one wet hand on each terminal of the biggest 6 or 12 volt battery you can find. In fact, I'll hold on to one terminal and put my tongue on the other of a 12 volt battery if you're willing to buy lunch when I barely feel it. And no, not only have I never heard of a mechanic being electrocuted by 12 volts(I was a mechanic for quite a few years), who ever told you it "does not happen often but it happens" did you a disservice. This is one of those situations where I'm guessing I'll never change your mind. In fact, I'm beginning to wish I'd never brought it up. But I assure you I am giving you good information...Al English
rhouston
06-28-2002 07:52:12
 Re: Re: Re: Re: Re: Electic shock from welding in reply to Al English, 06-27-2002 16:51:19
O.K I search for an actual incident last night and could find none. I remember one about 20 years ago. I have gotten a memorable jolt while under dashboard. imagine you are stuffed under dash with hand shoved over steering column and several air ducts and wiring harness trying to work on wiper transmission. its 90 degrees and your drenched. your head is pressed against metal support under dash (grounded). your elbow pushes against hot starter wire post breaking skin and drawing blood. if you cannot get away you cook slowly. It won't throw you death isn't quick but prolonged exposer is just as damaging (1000 amps at 6 volts = 6000 watts) respect amperage even at low voltage. Oh and put both battery cables on your tongue, you won't be able to taste the free lunch here is a link to someone else who supports my position. I too wish it wasn't brought up and I will now shut up !!!
http://www.zetatalk.com/health/theal04q.htm
Al English
06-28-2002 09:01:29
 Re: Re: Re: Re: Re: Re: Electic shock from welding in reply to rhouston, 06-28-2002 07:52:12
Hi rhouston,
I'm not one of those who has to have the last word, that's not why I'm responding.
Admittedly motor windings, relay coils, the ignition coil, or a capacitor, when energized buy 6 or 12 volts, can cause a shock. However, I wouldn't have posed the challenge I did without already knowing the outcome. I hesitate to admit this, but I have applied 12 volts directly to a cut just to see what would happen. At worst a slight burning sensation is felt. I have also tried the tongue thing. If the tongue is pushed firmly against the terminal it cannot be felt. If only a small spot is allowed to contact, a small discomfort sometimes occurs. And, I agree that an extended application couldn't do you any good. I read the link you posted. Without going into a lot of detail I'll just say that the poster's statements are misleading, uninformed, and are based on an incomplete understanding of the physics involved.
I hope I didn't come off like I was on your case. My only purpose for coming here is to learn things and help people. I will also shut up now...Al English
Jon Kraatz
06-27-2002 09:52:06
Just wait till the cars go to the new 42 volt electrical standard that is being proposed now for 2005. It will bring whole new methods and standards for the way people repair cars and my guess is that a lot of people are going to get hurt with it.
Al English
06-27-2002 16:55:39
 Re: Re: Re: Re: Re: Electic shock from welding in reply to Jon Kraatz, 06-27-2002 09:52:06
I agree Jon, I've had those same thoughts myself...Al English
rhouston
06-27-2002 09:29:56
of course normaly 6 volts isn't enough to conduct through your body. add a nice conductive layer of salty sweat and pow.
Nolan
06-27-2002 11:49:34
 Re: Re: Re: Re: Re: Electic shock from welding in reply to rhouston, 06-27-2002 09:29:56
Naw. If that was true, every mechanic on a hot day would have been electricuted. They aren't though. In fact, you can take your sweaty hands and place them directly across the battery terminals and nothing is going to happen. Your body has too much resistence for a mere 12 (or 6) volts to generate much amperage.
T_Bone
06-27-2002 09:17:34
Hi Steve,
I also been taught that the current(amps) is what constricts the muscles and causes deaths as the more current the person being shocked by can not let go because of the muscle contrations where as being hit with high voltage and sizeable current will usually blow off or burn off the offending body part.
That being said the most dangerous electrical shock that causes the most deaths is in fact 115vac at 10amps because of the muscle contrations is causes.
IMO high current always deserves greatest respect and more so than high voltage.
T_Bone
T_Bone
06-26-2002 22:26:04
Hi Bill,
Everyone has a different tolerance to electrical shock. Most handle it well enough that it doesn't bother them other than discomfort to temporary major pain.
Where most major injuries comes from is the reaction to the shock, jerking your arm into a sharp corner, bumping your head, falling off a ladder etc.
Scratch start Tig welding will probably give you your biggest "hit" while welding as you can get hung on the filler rod to the tungsten to ground. Such a good feeling when that happens. lol
Now if your talking the high voltage input side of the welding machine, all bets are off!
T_Bone
Gary
06-26-2002 21:25:11
There was a local man killed a few years ago. The way I remember it he was welding under a pickup in tight quarters, any way he was found with the electrode in his eye. I've been bit by them more than once but not real hard when on wet ground. Seems like mostly when I was going to move the ground clamp. So they warrant som care.
Al English
06-26-2002 20:03:41
Hi Bill,
As I remember the open circuit, no load, voltage across the output leads of your welder is about 110V. That drops to around 12 volts when a weld is in progress. While I've never heard of someone being electrocuted by a welder, as you can see, there is more than enough power available to do it. At the very least getting shocked isn't something you'd want to do very often(I'm somewhat embarrassed to admit I have ample experience in this area). Some people believe that in heaven you persist in the manner in which you died. How would you feel about carrying around an electrode holder with your hair standing up like Little Richard for the rest of eternity? Be careful...Al English
Alvin NE WI
06-26-2002 19:08:04
for one thing make sure you are not standing in water and holding the piece you want to weld at your welding bench and have a poor ground connection. don't grab a hold of wet welding rod after in the rod holder.. Maybe somebody can add to this. I know 220 volts will give a little attention
Jim WI
06-27-2002 10:50:10
 Re: Re: Electic shock from welding in reply to Alvin NE WI, 06-26-2002 19:08:04
700Vdc grabs your attention even better -- my arm twinges just thinking about that one (I didn't think that part of the overload relay was hot -- I'm sure glad I was following the one-hand rule).
JRN
06-29-2002 14:25:09
 Re: Re: Re: Electic shock from welding in reply to Jim WI, 06-27-2002 10:50:10
Dear Jim WI,
The "one hand rule"? Could you please explain?
Jim WI
07-01-2002 10:15:49
 Re: Re: Re: Re: Electic shock from welding in reply to JRN, 06-29-2002 14:25:09
Cubub's got it right -- if you only work with one hand on live equipment (and are careful not to make contact with any other part of your body), it's much safer because you can't get current through your heart.
In my case, there was enough clearance that I didn't gash my arm on anything when the muscles contracted (I also didn't make good solid contact anywhere -- that probably didn't hurt either).
Cubub
06-30-2002 05:57:42
JRN, I understand it to be safer (less likely to kill you) if the current doesn't flow from one arm to the other. So, it is best not to lean against the panel (or touch anything at "ground" potential) with one hand while working wih the other. Takes very little amperage at the heart to stop it from pumping blood. takes a very small amount of current (at the heart) to stop it from pumping, don't remember, I think they call it fibbrillate (sp?) when it quits doing the job, because they use a defibbrillator to attemp shocking heart into correct action again. Someone please correct me if I'm wrong again.
Go here:
Link
Then click on "Electrical safety"
rhouston
07-03-2002 13:58:26
 Re: Re: Re: Re: Re: Electic shock from welding in reply to Cubub, 06-30-2002 05:57:42
when working on electronics (monitors especialy)
you have to discharge picture tube. (most bleed charge off slowly nowadays but we discharge it anyway). anyway one hand rule is to grab the back of your pants or belt with the hand that isn't being used. this helps prevent the current from traveling from one arm to the other cause it passes through the heart along the way. The heart and brain are the ones we don't want to send all that current through
Cubub
07-04-2002 07:31:54
 Re: Re: Re: Re: Re: Re: Electic shock from welding in reply to rhouston, 07-03-2002 13:58:26
Thanks r, good idea.
Electricity has sneaked up on me before when not paying attention to it's wiley ways.
