Yet another Shop ?
John C.(ca)
06-23-2002 14:38:05
Hello: thought I might take a different approach... Getting ready to build my 30x50x12 shop. not sure if it will be metal or regular const. Here is the question... What in your shop would you change and why?
Thanks for any input..
John C. (ca)
Jeff Pack
06-26-2002 14:05:12
 Re: Yet another Shop ? in reply to John C.(ca), 06-23-2002 14:38:05
Airlines, 2 per side of the wall.
Room for 3 phase wire to be run, if not already.
Think you have enough lights? think again... :)
Outlets everywhere, including ceiling.
Welder outlets, 2 per wall.
Think about shelf space and racks.
Greg AZ
06-26-2002 08:27:58
To add to the excellent suggestions posted already, I would suggest a large, quiet air compressor. Mount it on a skid or pallet to make it easy to work on or move. Since the mounting pads that you can buy to mount compressors on are expensive, try cutting a piece of flat belting or even the sole of an old worn-out sneaker for vibration damping. My 10 horsepower Quincy compressor is mounted on a skid made of 4x4's and a piece of melamine covered pressed board sitting on old sneaker soles. The loudest part of the compressor is the magnetic starter snapping on startup. There is nothing more annoying to me than listening to a compressor that sounds like a jack hammer running all day. I recommend Quincy compressors for their quiet running and long life. Lots more money, but worth the investment. You also should build and install a good air drying system if you intend to paint vehicles or refinish furniture. A bead blast cabinet is a good tool to have if you intend to do any restoration work. Cuts cleaning time to almost nothing. My two cents.....All the best..... Greg
George
06-25-2002 18:17:41
For maximum wall-space flexibility and for security of the shop, no windows.
Install numerous skylights.
For maximum floor space flexibility, plan on the heavy, permanently mounted equipment (air compressor, mill, lathe, welding table, etc.) being placed around the walls of the shop. Occupy the center of the floor with movable work tables, cabinets and such. This way if a large project comes in, stuff can be shifted around to accomodate it.
Install a 200-amp service. Think about having a separate electrical meter for the shop instead of branching off the house -- in my area, it about $9 a month extra for the meter, but the power company is responsible for the power to the shop.
You can never have too many electrical outlets.
Get a rotary converter and place three-phase power outlets throughout the shop.
If you have heavy machine shop equipment, increase the thickness of the slab and add re-bar.
Have a variety of work areas -- enclosed shop, a carport area (for "smelly" work) and an open slab.
Having a roll-around gantry crane is a must if you are doing any heavy work.
(If I had a pizza oven in my shop, I would probably sell my house.)
John C. (ca)
06-26-2002 00:24:28
 Re: Re: Yet another Shop ? in reply to George, 06-25-2002 18:17:41
LOL....Great Ideas I'll look into that pizza oven.
I'll also check into having direct power too.
Thx
John C. (ca)
Gene
06-25-2002 17:57:48
i have read everything that everyone has written an the one thing that no one has mentioned yet is the air conditioning. if you are spending that large amount of money an putting in new heat, the air condtioning nothing, but it will make it so much nicer in the summer. it just keeps the heat down a little bit. if you insulate well enough it will not be that bad to run, espically if you keep the door closed when no welding or something like that. have exhaust outlets installed to. they are lifesavers.
John C. (ca)
06-25-2002 00:45:53
Thanks Guys for all of the ideas.. I printed them out and will add them to my file..
Thanks alot
John C.(ca)
JIM
06-24-2002 16:19:54
You have already received many good ideas.
I recently built a shop for about the same purpose and very quickly discovered one of the oldest laws of shop owners-your stuff will expand to take up every inch of available space. You never have too much.
I did mine with conventional construction; insulated three sides and ceiling. Electric 110/220. Water and drains.Windows entry door facing south-roof overhangs 2 feet on both sides-really nice steep pitch to the roof.The fellow who wired mine did something that really made a diference. He set outlets all over the ceiling which is 15 feet tall, as well as the wall outlets all around the shop. The ceiling outlets all have drop cord 15 foot, bright yellow extension cords on recall reels. That way I can drop power to anyplace in the shop from over head and not have cords lying all over the floor. Saves a ton of time and swearing.
Jim
Mac
06-24-2002 15:41:27
Definately gotta have a TV, Refrig and last but not least a nice couch to snooze on cause when you get done spending, you will surely be in the dog house.. Just funnin...Good luck on what sounds like a super project..A lot of us have probably wished our foresight was as good as the hind sight. Me for sure..
Bruce L.
06-24-2002 12:58:18
Here some of my suggestions after building my second shop.
Go to 14 foot height. If you live in a northern climate face the doors south. Have the roof slope to the sides and not dump in front of the doors. Consider a mezanine for upper level storage in the back of the building. Consider in floor heat if you have to heat the building. Floor drains. Stub in the plumbing for a toilet. Consider using a spred web truss design for attic storage. When you bury your electric power cables put in phone and video cables also. Do you have an RV? How about putting in your own dump station. Anchor points in the concrete floor are nice for pulling things. Put some kind of sink close to where your grinder will be located. Things like two post floor hoists require special footings. A footing for the post that holds up your mezanine would be good also. A satellite dish with a wall mount plasma TV would be nice. Also don't forget a refrigerator.
Bruce L.
Jet9N
06-24-2002 16:05:10
 Re: Re: Yet another Shop ? in reply to Bruce L., 06-24-2002 12:58:18
Excellent list. The only addition I can think of
is to put in a 3/4 " polyethylene pipe. This lets you add more communication wires at any time.
Jet
JerePa
06-23-2002 17:17:53
Ceiling high enough for whatever kind of hoist you will use. Doors wide enough to get in & out of without having to worry about hitting. Do everything now. Don't put off putting in windows, spouting, etc. Make sure the floor is settled & compact before putting in the concrete. Put plastic down before pouring concrete.
Keith Morris
06-23-2002 16:28:53
Ok bigger add more electric outlets 110 and 220 install 3 phase if possible overhead hoist that runs the complete length of the shop. See I can have fun spending someone elses money. Cuz I dont got enough
John C. (ca)
06-23-2002 23:15:11
 Re: Re: Yet another Shop ? in reply to Keith Morris, 06-23-2002 16:28:53
I know about wanting to spend other peoples money..lol.
Wish it could be bigger but the county limits outbuildings to a total of 1600ft. So I am limited in size. Will have lots of outlets, 3ph will be out of the question for now. I am thinking of a portable A-Frame hoist so it will be where I need it.
Thanks to all for the replys
F14, with The Universal Answer
06-23-2002 14:43:47
"I'da made it BIGGER"...
Other than that, I'm pretty happy with the way mine came out, but then I spent the last 10 years I was in the Navy thinking about the shop I was gonna build when I settled down.
