Homelite chainsaw
MG-Oregon
06-23-2002 07:04:27
Homelite chainsaw 2.3 cubic inch 18inch bar 1999 model. Fuel delivery problem getting worse, was hard to start hot,now all the time. Checked and cleaned tank filter now where do I go. I have very little experience with two cycles. Well fire easy with start fluid, but struggles to keep running and seems low power.Does anybody have a parts picture of these things.Thanks in advance for your help.
dave konkin
11-17-2005 21:05:04
 Re: Homelite chainsaw in reply to MG-Oregon, 06-23-2002 07:04:27
I have an older (1986) Homelite XL76. The fuel
problem on mine is caused because the fuel tank is not independent of the engine. Therefore the fuel boils.
Solution. cut a little then split your wood or
clean-up a little so the fuel in the tank cools down. Also loosen off the fuel cap to let it cool
faster. AND NEXT TIME YOU BUY A CHAINSAW MAKE SURE THAT THE ENGINE AND FUEL TANK ARE INDEPENDENT OF ONE ANOTHER. GOOD LUCK
BillW
07-10-2002 09:34:51
If the spark arrestor screen is getting carboned over, your mix ratio is wrong. Make sure its as exact as you can, particularly if you are using the 50:1. A'little 'extra oil' can give you other problems as well. (See "2-cycle fuel mix" topic)
Al R
06-25-2002 18:58:40
Best solution for a Homelite chainsaw is to climb high in tree, preferably over a concrete driveway and drop the saw. The new homelites are nothing but junk. Just ask the tree trimmers that trim trees around the power lines.
John Green
09-18-2004 13:25:12
 Re: Re: Homelite chainsaw in reply to Al R, 06-25-2002 18:58:40
I have a Homelite that works fine ever since I took the spark arrester off. (I believe the arrester is required in CA)
bob
06-25-2002 20:35:21
thats been good advice for at least 20 years
Chris C.
06-25-2002 17:09:50
Amen to both of the previous post. Also, check your reed block, I had one that had a small crack that caused similar symptoms
Catskill Pete
06-24-2002 05:46:58
Another vote for remove spark screen from muffler. Those Homelite's will drive you crazy. Acts like fuel problem but is actually restricted exhaust.
John in MA
06-23-2002 10:27:40
First, rebuild the carb. Second, clean or remove the spark screen in the muffler. You don't want to use starting fluid in chainsaws because it doesn't have any oil in it.
Ross
06-25-2002 20:41:12
 Re: Re: Homelite chainsaw in reply to John in MA, 06-23-2002 10:27:40
Not to disagree with you John as to whether or not to use starting fluid on a chainsaw but I have a can of starting fluid from NAPA which claims to have lubricant in it as well as a starting agent. I believe most starting fluids have this lubricant in them anymore
Just my .02 worth
Ross
