Another Shop Question Pls
ShepFL
06-22-2002 16:04:44
I am thinking of adding bollards (sp?) at the outside corners to my main entrance door. This way if I or someone else is backing a trailer in they hit those instead of shop. Trying to prevent future potential damage (sons growing up!!).
Question is this - what is the insulative value of concrete? I am thinking of adding a water spigot atop the outermost bollard. This would be 1" Schedule 40 PVC inside 6" dia. 1/4" thick pipe. Pipe will be buried to a depth of 3' with 4-5' sticking above grade. Location is N. FL. Comments?
MarkB
06-23-2002 05:55:52
 Re: Another Shop Question Pls in reply to ShepFL, 06-22-2002 16:04:44
I wouldn't put a spigot inside a concrete-filled pipe. Not because it is likely to freeze, but because there's no way to fix it if it does freeze.
I would use a freeze-proof yard hydrant, although that's probably overkill for FL. Back in NC, a lot of guys would run a pipe inside a 3-4" PVC pipe, and fill the larger pipe with sawdust. If it gets very cold, you need to let the spigot drip.
Side note: When I lived in NC, frozen pipes were a common occurrence every winter. Now that I live in MI, I never hear about frozen pipes!
MrG
06-25-2002 06:59:25
 Re: Re: Another Shop Question Pls in reply to MarkB, 06-23-2002 05:55:52
That's 'cuz there ain't as many mobile homes in Michigan...
Jhill
06-24-2002 05:38:30
You haven't lived in Mi long then.
VaTom
06-22-2002 19:50:46
Hi Shep,
You might want to think about a self-draining hydrant. Concrete, depending on makeup, is around R .2/in. Lightweight aggregates like vermiculite or pumice will reduce the density and increase the R value upwards of 1/in, while reducing your protection.
