Welding zinc plated casters?
DumOleBob
06-21-2002 10:13:24
I need to mig weld four small casters to the bottom of a fan frame. I believe the casters are �zinc� coated or something like zinc. I know the zinc has to be removed at the weld? What is the best way to get the zinc out of the way - grind? Acid?
Nathan(GA)
06-21-2002 10:31:06
 Re: Welding zinc plated casters? in reply to DumOleBob, 06-21-2002 10:13:24
Grind is the easiest. If it's that bright coating that comes on most casters I've seen, you can weld without doing anything to the coating.
