Cast to steel
Doug Rogers
06-20-2002 07:25:39
Need to weld some cast iron to steel. What kind of rod should I use with an AC arc welder?
Dan
06-21-2002 03:56:23
 Re: Cast to steel in reply to Doug Rogers, 06-20-2002 07:25:39
Is this cast iron and steel material going to be an item that is heated , example exhaust manifold or fire place? Do you have an oxygen / acetylene torch set up? The reason for my questions is because cast iron is a very difficult metal to weld on with an arc welder and not have the weld crack right along the edge.Ideally you need a furnace to heat the entire peice. If the joint isn t heated when in service I prefer to braze weld cast iron to cast iron or cast iron to steel joints using bronze filler metal.
cannonball
06-22-2002 05:49:45
 Re: Re: Cast to steel in reply to Dan, 06-21-2002 03:56:23
just welded a exh manifold that i broke off by hanging a limb on exhaust cover used ss rods..tried cast they would not hold at all..
jake
06-21-2002 11:11:59
Steve from US Alloys told me how to weld cold, the secret is to use short beads and keeping the temp under 300 degrees. If no cracks are to be welded and steel is joined the temp may not be critical however Steve from US alloys is the perfect person to talk to. Also check www.twoguysgarage.com, in their archives is cold welding of cast iron, I saw the show and it was impessive.
Norman
06-20-2002 11:32:11
Doug,
Get ahold of Steve at [email protected] He is with U.S. Alloys. I bought some and it works. Later
Norman
jake
06-20-2002 20:22:59
 Re: Re: Cast to steel in reply to Norman, 06-20-2002 11:32:11
Go to the US Alloys[use google], click cast iron and look up their 924 rod it's made for joining cast and steel. Not cheap but it works.
US Alloys website......T_Bone n/t
06-20-2002 20:55:31
 Re: Re: Re: Cast to steel in reply to jake, 06-20-2002 20:22:59
nt
