What kind of welding rod?
Darrell C.
06-19-2002 03:38:25
What kind/size of welding rod do I use for a verticle weld-to-weld on 1/4" truck frame? Thank you Darrell C.
T_Bone
06-19-2002 07:27:09
 Re: What kind of welding rod? in reply to Darrell C., 06-19-2002 03:38:25
Hi Darrell,
You might want to explain what you mean by weld-to- weld?
I like 1/8" 7018 dcrp Chemtron but you can also use 6010, 6011.
Depending on what brand truck frame you planning on welding, most newer mfg's have a welding procedure to follow. Most of the spec's are vertical welds with NO connecting horzontial welds. Example:
Vertical welds on a 4" long angle iron bracket would be 1-1/2" on the top & bottom web side of the angle with 1-1/2" long weld in center of opposite side.
Under no circumstance would you weld the bracket all around as that intraduces stress upon the frame.
Fillet leg thickness would be the thicker of the thinest metal. Example:
a 1/4" thick truck frame and a 3/8" thick angle iron then the weld leg would be 1/4" or a 3/8" frame with a 1/4" thick angle, the leg would be 1/4"
or a 3/8" frame with a 3/8" thick angle, the weld leg would be 3/8"
T_Bone
roy
06-19-2002 18:36:01
 Re: Re: What kind of welding rod? in reply to T_Bone, 06-19-2002 07:27:09
I like 7018 with revse pol.
