Electrical code
Rod MI
06-16-2002 15:47:29
I whose just wondering what is the minimum amount of wire that can be extending out of the electrical box? My house has about 2 to 3 inches I thought sum one seed 6 inches is the minimum thanks and can I buy a book that tells you these codes thanks
Thanks!
06-17-2002 09:33:29
 Re: Electrical code in reply to Rod MI, 06-16-2002 15:47:29
Thanks!
Farmer Tom
06-17-2002 06:54:20
For current code requirements, you will find your answer in NFPA 70-02 (NEC 2002) in Article 300, Section 300.14. However, check with your local electrical inspector to see what your local requirements are; they might not be using the current NEC; may even have an adopted localized code instead of the NEC!
Farmer Tom (city electrical inspector)
Jim K
06-16-2002 17:17:36
The code requirement is six inches but I like 7
you should be able to buy a code book for about 80.00 dollars from any electrical supply house. But you'll need a good lawyer to decipher it.
What I would do is go to a good book store and pickup a good handymans book that has electrical tips in it.
Jim K
By the way I'm an electrician.
